Marking on Ice
9 replies to this topic
#1 Ryan McGregor
Ryan McGregor
  • 8 posts
Posted 28 May 2009 - 01:02 AM
I am assisting on a Mini Series that takes place on a hockey rink, we have been using regular colored markers (often smelly markers) on the ice as marks. They have been great, only problem is that the ink really sinks in deep into the ice and it's really hard to scrape it off. Anyone have any suggestions for something that is a bit easier to remove?
#2 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 28 May 2009 - 02:17 AM
Perhaps some chalk powder would work. It probably wouldn't sink into the ice (probably a little, but not as much as ink), and if the ice melts around it, it'll most likely just clump up and be easy to scoop away.
http://www.amazon.co...n...792&sr=1-20
I don't know for sure, but it could be worth a try.
#3 David Rakoczy
David Rakoczy
  • 1579 posts
  • USA
Posted 28 May 2009 - 07:50 AM
..a quick dot spray of Streaks & Tips?
#4 Adrian Sierkowski
  • 7375 posts
Posted 28 May 2009 - 08:53 AM
Perhaps, if possible, make up some cardboard markers with colored tape and see if you can secure it into the ice with a small tack/nail, then you just pick it up and go?
I'll be in a similar situation this October on a shoot, a mockumentary on hockey moms, so I'm interested in any ideas.
#5 Gareth Roberts
Gareth Roberts
  • 12 posts
  • Nova Scotia, Canada
Posted 28 May 2009 - 11:08 AM
Use Bingo Dabbers. They come in different colors and the marks don't sink into the ice.
Gareth Roberts
#6 Chris Keth
Posted 28 May 2009 - 02:28 PM
I'd take some rubber matting and make some little T marks and stick a thumbtack through them.
#7 David Rakoczy
David Rakoczy
  • 1579 posts
  • USA
Posted 28 May 2009 - 02:56 PM
I like that Gareth! Evidently living in Canada you have some experience with ice!
#8 Brad Grimmett
Brad Grimmett
  • 2660 posts
  • Steadicam Operator
Posted 31 May 2009 - 03:30 AM
I don't think putting any kind of marks that could trip an actor while on ice are a great idea. Just a thought.
#9 John Waterman
John Waterman
  • 49 posts
  • Chicago
Posted 04 June 2009 - 12:50 AM
I'd use hard marks for that. Go to a hardware store and purchase some metal framing Ts. Then wrap them with camera tape in different colors. The Ts have holes where you can secure them to the ice with a small tack or nail, but because they are metal they usually stay put, and they are thin, so people don't bump into them as much as the sandbag style Ts. I have a small loop of rope attached to my hard marks, so I can have a whole set hanging from a hook on my cart or belt. Another plus, the framing Ts cost $3.50 ish where the filmtools sandbag Ts cost $15. And you can change the color at any time with a bit of camera tape.
#10 Chris Keth
Posted 04 June 2009 - 10:23 PM
If you wanted to use those on ice you could stick some traction tape for stair treads on them.
