Sony EX3 PAL buy in Tokyo
#1 Stuart Page
Stuart Page
  • 41 posts
  • Auckland, New Zealand
Posted 29 May 2009 - 05:06 PM
I need to buy 2x Sony EX3 PAL cameras in Tokyo, any ideas? I also need to get memory cards, mics, batteries, tripods and camera bags. Is it easy to get PAL versions of this camera in Japan?
#2 Chris Millar
Chris Millar
  • 1642 posts
Posted 30 May 2009 - 05:44 AM
Stu, both the EX1 and EX3 are PAL/NTSC independent - they shoot both formats
:P
#3 gavrosh haxhihyseni
gavrosh haxhihyseni
  • 16 posts
  • Albania
Posted 31 May 2009 - 11:06 AM
Edited by gavrosh haxhihyseni, 31 May 2009 - 11:07 AM.
#4 Stuart Page
Stuart Page
  • 41 posts
Posted 01 June 2009 - 03:51 AM
:P
F*kn brilliant. Those EX3's are just too good !!! :rolleyes:
#5 Adrian Sierkowski
  • 7375 posts
Posted 01 June 2009 - 05:59 AM
Isn't Japan an NTSC/60Hz country, though? So If you're shooting PAL (25P) I'd recommend making sure your EX shutter is @ 1/60th to avoid flicker.
Edit: Some searching, and actually Japan, according to this webpage is a 50/60 country... Depending on where, Tokyo being a 50 Hz area.
http://www.kropla.com/electric2.htm
#6 Phil Rhodes
  • 12175 posts
Posted 01 June 2009 - 09:19 AM
I've shot quite a bit of (interlaced) PAL video in 60Hz countries. Typically, a very small amount of flicker is just about visible with discharge lights, but it's not shot-wreckingly bad if you do happen to get it wrong.
#7 Robin R Probyn
Robin R Probyn
  • 2231 posts
  • Tokyo
Posted 01 June 2009 - 09:51 AM
Yes Tokyo is 50hz, but if you are going down to Kyoto,or Osaka it becomes 60hz..but the TV system is NTSC all over Japan.
You probably wont get an English manual,but I think you can down load one.
#8 Yasuaki Iwamoto
Yasuaki Iwamoto
  • 1 posts
  • Tokyo
Posted 02 June 2009 - 04:03 PM
it's all in Japanese . . .
pro video equipment stores in Tokyo
1: video kinki
product info: http://www.videokink...em.html#PMW-EX3
map: http://www.videokink...jp/zk_shop.html (Tokyo show room: bottom map)
nearest station: Shinjyuku
2: system 5
product info: http://www.system5.j.../item35505.html
map: http://www.system5.j...tail/tokyo.html
nearest station: Kanda
3: tsukumo capture
product info: http://capture.tsuku...00510051000000/
map: http://capture.tsukumo.co.jp/ (page bottom)
nearest station: Akihabara
4: fujiya-avic pro shop
product info: http://www.fujiya-av...op/xdcamex.html
map: http://www.bwy.jp/map.html
how to access: http://www.fujiya-av...how2access.html
nearest station: Nakano
#9 Phil Rhodes
  • 12175 posts
Posted 02 June 2009 - 08:01 PM
Ah, well - ame futte ji katamaru.
-P
