Arri BL 2 Buckletrip Switch
#1 Gary Robinson
Gary Robinson
  • 54 posts
Posted 08 June 2009 - 11:04 AM
Hi Guys,
I finally got my lemon Arri BL 2 fixed to the point it's useable. The motor is working, but when I load some mags, and start to run the camera, the buckletip switch is switched almost immediately, turning the motor off. Normally this switch is tripped at the end of a roll. Is this switch tripped by improper film loading? Can the switch be removed? What problems can lead to this switch being activated?
#2 Tom Jensen
Tom Jensen
  • 1234 posts
  • Dallas, TX
Posted 08 June 2009 - 11:15 AM
Hi Guys,
Try adding another perf or two to the loop. You can take it a little past the notch. If it's too long it will hit the top and bottom of the inside of the camera. Just test it for scratches after you try a longer loop length. DO NOT REMOVE THE SWITCH. You want to avoid camera jams. You can ruin your movement. The trip is there for a reason.
