Economical 2k light for ambience?
#1 Salil Sundresh
Salil Sundresh
  • 101 posts
  • 2nd Assistant Camera
Posted 12 June 2009 - 03:28 PM
Looking for an economical high output fixture/setup that will give me ambient light on a set. The Arrilite 2k is more than I'd like to spend. Any ideas? I was thinking about using a bunch of work lights rigged together through a silk or something, but also considering florescencts due to their efficiency.
#2 Adrian Sierkowski
  • 7375 posts
Posted 12 June 2009 - 03:36 PM
used mole richardson 2Ks can be found on e bay, the junior solar spots, are nice, but you should also look into a mighty mole, the 2K open face fixture.
#3 Chris Keth
Posted 12 June 2009 - 03:37 PM
If you want soft and economical, a space light is tough to beat. If that is too expensive, you could use 4 large (30 or 36 inch) china balls, each with a 500W lamp inside.
