Sodium Vapor
#1 Nadav Hekselman
Nadav Hekselman
  • 68 posts
Posted 17 June 2009 - 01:37 AM
(Moved from incorrect forum)
Hey everyone,
I'm about to shoot a short on August with a lot of night exteriors. Most of the locations are streets in Tel-Aviv which are usually lit with the famous sodium vapor lights (the low pressure yellow-orange ones).
I'll probably be shooting on EX3 or F900 and looking for the best way to shoot those lights. I want to keep their yellowish quality but in a nice and natural way. According to some tests I did I fear a simple WB wont be enough and some camera or post manipulation are needed. any advice on camera settings? WB? post work?
Also I need some advice with gel configuration for matching 3200k light to the sodium ones. A configuration that will be nice for skin tone.
Any other advice on handling those vapors will be appreciated.
Thanks.
#2 Jose Figueroa Baez
Jose Figueroa Baez
  • 36 posts
  • 2nd Assistant Camera
  • New Orleans, LA
Posted 17 June 2009 - 10:30 PM
Hey everyone,
Thanks.
See if you can get the color cards for warming and cooling your image. Those can help you get a better control of how your image will come in that light by white balancing with those instead of a plain old white board. You can also try and fiddle with the colors in post keeping your mid tones at a more normal level and letting your highs go to the orange tones. That should give you an interesting image.
#3 David Rakoczy
David Rakoczy
  • 1579 posts
  • USA
Posted 18 June 2009 - 08:37 AM
Nadav,
Double posting (posting the same question in two different lists) is a no no... it is better off where you originally posted (Lighting).
#4 Nadav Hekselman
Nadav Hekselman
  • 68 posts
Posted 19 June 2009 - 01:59 AM
Nadav,
This was actually the first place I posted. I did it accidentally and couldn't find a way to erase it. Sorry.
#5 Santiago Benet
Santiago Benet
  • 20 posts
  • Puerto Rico
Posted 01 July 2009 - 11:45 AM
Hi , recently I worked with DoP Dariuz Wolski and we had in our lighting package a series of sodium vapor fixtures ( 75w,250w, 400w, 1000w commercial fixtures ) wish he used instead of correcting tungsten lights and it looked great he told that he has been doing this for a while you can see it on the movie eagle eye it looks great. other people i have worked for use other formulas for example Robert Elswitt used a gel called lee 232 super white flame and it was similar to sodium vapor. But Wolski's formula is the exact same color tone and if you have a good grounded power you should have no flickering. I know that rosco has a corection for sodium vapor we used once with a 6 k hmi and looked good too. Now days source maker manufactures sodium vapor ballons. I did a commercial recently with RED cam and we had a night exterior and applied the Wolski way and it looked awesome. I hope this help you in some way.
