Conversion LOMO anamorphic roundfront BAS on Superspeed anamorphic F = 35/1.8 , F = 50/1.5 , F = 75/1.7 , F = 100/2.0
No replies to this topic
#1 Sergey Kravchenco
Sergey Kravchenco
  • Banned
  • 83 posts
  • Best Boy
Posted 18 June 2009 - 04:29 PM
Hi !
Now our optician made conversion anamorphic lens 35BAS25 - 2 , F = 100/2.8 , T = 3.4 - will replace optical block on another OKC1-100-1 , F = 100/2.0 , T = 2.3 and lens will more faster ..
Optical block OKC1-100-1 T=2 more about 10 mm in diameter then optical block OKC2-100-2 which fitted on rear part ( submount ) of original anamorphic lens 35BAS25-2 , therefore it is not possible only replace one optical block to another . Now our optician made new submount ( rear part ) from hard black anodized aluminum ( it more large in diameter then regular anamorphic lens 35BAS25 - 2 ) , new iris ring with new engraving , new anamorphic lens F = 100 /2.0 will has T=2.3 .After lens carefully collimated .
If you want to convert your lens on more faster – price of conversion $ 1900 .
And the same conversion it is possible to make from LOMO roundfront anamorphic lenses :
F = 50 /2.0 type 35BAS22 – 1 and F = 75 /2.0 type 35BAS23 – 2 – this type of lenses has absolutely equal front anamorphic part – difference only in rear part with prime lens and with this front anamorphic part it is possible to made else some anamorphic lenses F = 135/2.8 and F = 150 / 2.8 – I have bought some lenses and buyers was very happy .
Now our opticians finish work for conversion LOMO anamorphic F = 35/2.5 type 35BAS27 – 1 , was made new rear part and fitted in it Superspeed block OKC12 – 35 – 1 , F = 35/1.4 now lens has F = 35/1.8 and it is the same conversion make for lens 35BAS22 – 1 , F = 50 /2 and 35BAS23 – 2 , F = 75 /2 – replaced prime lenses with standard speed on block of prime lenses superspeed .
If you want to order conversion your LOMO roundfront anamorphic lens :
35BAS27 - 1 , F = 35 /2.5 on superspeed F = 35/1.4 , T= 1.8
35BAS22 - 1 , F = 50/2 on superspeed F = 50/1.2 , T = 1.5
35BAS23 - 2 , F = 75/2 on superspeed F = 75/1.4 , T = 1.7
35BAS25 - 2 , F = 100/2.8 on superspeed F = 100/2 , T = 2.3
If you need additional photos or any information please contact with me :
sergastr@list.ru
sergastr@yahoo.com
Best regards
Sergey
P.S. - the price of ready Superspeed lenses from me $ 4900 + shipp.
