Wide angle and K3 with M42 mout
#1 Raz Birger
Raz Birger
  • 46 posts
  • Israel
Posted 29 June 2009 - 11:00 AM
Hello guys,
I have a Krasnogorsk-3 with M42 mount and I want to get a wider angle of view.
Would it be wise to buy a wide angle attachment like this one?
http://www.cavision....al/LWA07X77.htm
I think these attachments were made for lenses that have a wider angle than what you get with Krasnogorsk's Meteor at 17mm and it may not be effective to use.
Peleng 8mm would be more expensive and I am not looking for the distortions of a fisheye lens (I know it's less visible on 16mm film, but I watched some footage and it is still visible enough).
Is there any other solution or should I go for the attachment?
Best Regards,
Raz Birger.
#2 Olex Kalynychenko
Olex Kalynychenko
  • 868 posts
  • Dnepropetrovsk, Ukraine
Posted 30 June 2009 - 07:32 AM
Hello guys,
Best Regards,
Raz Birger.
I think, to use of 0.7x adapter possible with Meteor-5 17-69 mm zoom lens.
Meteor-5 have M77 screw mount from front side and 0.7x adapter can be fit.
Any case, you can test.
Maximum wide angle of view must be like 0.7x 17 mm = 12 mm.
K-3 with bayonet mount can be use with upgraded 16OPF-12 zoom lens 10-100 mm.
10-100 mm zoom lens can have 0.75 x front wide angle attachmnet and work very fine with K-3 + 10-100 + 0.75 x.
#3 Raz Birger
Raz Birger
  • 46 posts
  • Israel
Posted 30 June 2009 - 08:43 AM
Thank you for your answer Olex.
I can't test the adapter, I have to order it, it's not in stock wherever I look. There are only attachments for tinier screws like 72mm 58mm 37mm.... Larger than these should be ordered.
If I had a bayonet K3 it would have solved the problem, but I have already got one with M42 mount.
Are you sure about your calculation? I have always thought the ratio (0.7x) is of the angle of view and not of the focal length. So the calculation should be like this:
Angle of view formula: 2*tan-¹(0.5*L/F)
(L - length of the film, in 16mm it is about 10mm. F - focal length, 17mm Meteor's widest)
2*tan-¹(0.5*10/17) ≈ 32.8°
Then 32.8/0.7 gives us 46.8°. Using the formula the focal length of this angle is 11.55mm. OK it's not so far from 12mm like you said :lol: .
Anyways, I am also wondering how such an attachment will effect focusing? (I am talking about staying on the widest angle without zooming).
#4 Rudy Velez Jr
Rudy Velez Jr
  • 225 posts
Posted 17 November 2013 - 05:11 PM
The Peleng 8mm is good option the closer you get with the lens you can see slight distortion but its a great wide angle lens option with awesome DoF
Edited by Rudy Velez Jr, 17 November 2013 - 05:12 PM.
