ACL & NPR Rod Support
#1 Jason Hinkle (RIP)
Jason Hinkle (RIP)
  • 240 posts
  • Chicago, IL
Posted 01 July 2009 - 11:08 PM
If anybody's looking for a rod support for the ACL, Seth at American Cine Spec just designed one: http://www.americanc...ges/Eclair.html Mine just showed up today and I have to say it's extremely solid. The mount plate is offset to the side so the rods sit correctly under the lens on the ACL. I tried two other "standard" rod supports and they didn't work very well on my ACL because I couldn't adjust them far enough over to work with the way lens mount is off to the left (relative to the tripod mount/hole). This one's especially cool since it's custom designed specifically for the ACL, it fits perfect & doesn't get in the way of the anatomic grip.
I talked on the phone for a while with Seth and I know he's still feeling out the market for making custom parts for Eclair cameras so if you want one I'd definitely recommend giving him a call. I know he's also made a prototype for the NPR, I'm not sure if he's selling them yet - probably based on whether anybody contacts him about it.
Here's some pictures (He cut down the rods for me, which is why these are kinda short):
Edited by Jason Hinkle, 01 July 2009 - 11:11 PM.
#2 Patrick ODonnell
Patrick ODonnell
  • 26 posts
Posted 09 July 2009 - 07:02 PM
His website says the rods are for ACL 1 and 1.5 models -- do you know if they will fit an ACL 2? And apparently it attaches by screw through the hole where the camera plate attaches -- did you experience any problems with this set-up?
#3 Jason Hinkle (RIP)
Jason Hinkle (RIP)
  • 240 posts
  • Chicago, IL
Posted 10 July 2009 - 07:42 PM
Seth was looking for somebody with an ACL II to measure the bottom plate so he can make a rod support for that too. From the pictures I've seen the ACL II base sticks out quite a lot further. I think if you sent him the measurements, he is interested in adding it to his product line. He makes each one by hand as I understand it.
I'm fairly used to the way it attaches to the bottom because my previous one worked like that. only difference is that this one fits the base exactly with a little lip to keep it from spinning. Unlike my previous generic one, which was thin/cheap metal and prone to coming loose (not to mention the off-center lens problem). This one is super solid and fits perfectly tight onto the base plate.
