Tips for shooting on the beach
7 replies to this topic
#1 Tony Coan
Tony Coan
  • 18 posts
  • Philadelphia, PA
Posted 08 July 2009 - 10:32 PM
So I am helping a friend out this weekend, SR3 and the beach.
Never shot on the beach before.
The film is a very short narrative.
We will be using a splashbag for some parts.
And I have friday to checkout.
Any tips/hints/suggestions?
#2 Chris Keth
Posted 09 July 2009 - 01:33 AM
There will be saltwater spray, no matter what. Unfortunately, it really likes to leave awful streaks when you clean it so the best thing I have found is to shield the lens from it as much as possible. I like to keep a flat in front of the lens for rehearsals and I'll pull it right before takes. That helps me keep the glass clear, while also giving full use of the viewfinder for rehearsals.
#3 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 09 July 2009 - 04:16 AM
A shower cap is a great way to cover the lens while it's not being operated.
#4 David Auner aac
David Auner aac
  • 1117 posts
Posted 09 July 2009 - 04:25 AM
Hehe, imagine an genuine ARRI shower cap. The DEFINITIVE for the Arri aficionado who has EVERYTHING!
Cheers, Dave
PS: A UV filter might also be a good idea to keep on the lens. Removes that excessive blue on a hazy day. I used UV filters to protect our SLR lenses on a beach shoot last year. Worked great!
#5 Chris Keth
Posted 09 July 2009 - 04:21 PM
That's a killer idea. Can you get clear enough shower caps that the operator, DP, etc. can still see to frame up and everything with it on?
#6 Tom Jensen
Tom Jensen
  • 1234 posts
  • Dallas, TX
Posted 09 July 2009 - 04:44 PM
I carried a shower cap in my bag of tricks. Use an optical flat and pull it before you shoot or leave it in and keep it clean. It all depends on how much wind, sand and water is being kicked up. I carried a paint brush so I could clean the tripod and cases before putting it in the truck. Leave the caps on the mags up until the point you reload, I mean last second. Reload in a truck if you have to. Canned air. Blow off the mag before you remove it from the camera. Use a camera cover. Bring a hair dryer. Sunscreen. Forget spreaders. Lay a furny pad on the sand and put equipment on that. I'll think of something else.
#7 Sam DiGiovanni
Sam DiGiovanni
  • 5 posts
  • Chicago, IL
Posted 10 July 2009 - 03:26 PM
Press n seal cling wrap. Its great for keeping sand / salt spray off the camera and monitors especially in all the little nooks. It can leave a little bit of a residue, but it cleans off with minimal effort.
#8 Ollie Bartlett
Ollie Bartlett
  • 88 posts
  • Bristol, UK
Posted 11 July 2009 - 01:45 PM
4x4 poly bags. Lots of them.
Great for putting over the camera and sticks when changing lenses. You've got room to maneuver, and they keep the salt and spray away from the sensor or film while the lens is off. You can put them over every bit of exposed kit when lunch is called as well.
Also good for keeping half eaten sandwiches in, so as not to get sand blown on them (do not use the sandwich poly bag for a lens changing bag! I should imagine mayonnaise is worse than sea spray for sensors)
