C-Stand situations
#1 Joe Riggs
Joe Riggs
  • 68 posts
Posted 10 July 2009 - 12:36 AM
Two questions
On a professional set, is moving a c-stand with a flag attached frowned upon? For example if you have two camera setups, the first one takes place 10 feet away from the 2nd, is it acceptable to move the stand with the flag attached to the next setup? or should you always remove the flag, fold the c-stand, and set it up again? or does it depend on length your walking with it and location (interior/exterior?
If there is no taco cart, what is the proper way to place c-stands you're not using, or when wrapping at the end of the day? On the ground? Against a wall?
thanks
#2 Darryl Richard Humber
  • 143 posts
  • Grip
Posted 10 July 2009 - 12:58 AM
Two questions
thanks
No it's not frowned upon unless it's impractical, unsafe or inefficient, and is going right to work on another light.. It also depends on what your Key likes or dislikes. Every one has his own quirks, but in general it's fine. Once a stand is opened to work, there's no reason to close it again until it's packed away for a move etc. Don't overthink it too much, it's all about efficiency. If you're coming back to the same place the next day, stack them opened in the staging area, out of the way of other departments. Always stack c-stands, big legs over small ones, so that the stand closest to set is the first one off the stack.
#3 steve laramie
steve laramie
  • 24 posts
  • Philadelphia
Posted 15 August 2009 - 07:42 PM
As long as you arent flying the flag out when you move it I dont see it being a problem. Just bring the arm down and keep everything as compact as possible and then move it.
