toe-in(stereoscopic question)
#1 michael abraham
michael abraham
  • 36 posts
Posted 18 July 2009 - 04:43 AM
Hello,
special 3D stereoscopic question:
is it better toe-in on the lens' nodal point,film plane or camera's body?
If the convergence(toe in) can be adjust on the lens' nodal point or film plane,will the keystone effect be improved?
Thanks a lot :rolleyes:
#2 Russell Scott
Russell Scott
  • 42 posts
Posted 21 July 2009 - 08:01 PM
Hello,
can I suggest you don't toe-in at all? then you'll have no keystone effect...
if you do toe-in, you'll need to find the film plane - assuming we're using the same terminology :lol:
#3 michael abraham
michael abraham
  • 36 posts
Posted 24 July 2009 - 03:59 AM
Hi Russel,
thanks for your reply.
as you know there are different point of view.I prefere don't toe-in and do it in post but there are different stereographer that prefere do it in shot.This was the reason for my question.
I don't understend your last sentence(about film plane).Could you explain it to me please?
My question was:what is it the right point(pivot/rotation point)to toe-in the camera?
All the best!!!
#4 Olex Kalynychenko
Olex Kalynychenko
  • 868 posts
  • Dnepropetrovsk, Ukraine
Posted 24 July 2009 - 04:39 AM
for note, russian stereoscopic
http://www.stereokino.ru/ennews.htm
#5 Russell Scott
Russell Scott
  • 42 posts
Posted 26 July 2009 - 09:35 PM
Hi Russel,
as you know there are different point of view.I prefere don't toe-in and do it in post but there are different stereographer that prefer do it in shot.This was the reason for my question.
All the best!!!
yes I figured you'd say that (about hte toe-in/ no toe-in :P )
my answer was that, as long as we're using the same phrases, the film plane is the correct rotation point. (I've never called it a 'film plane" so I'm assuming what you mean by that). Having said that, your keystone won't be improved, but your stereo would be.
Keystoning is a result of the vertical parallax that toe-in introduces, so while the keystoning would be more accurate when you identify the correct rotation point, it doesn't follow that by correctly rotating , your keystoning would be reduced.
an example would be if your original rotation point caused you to effectively rotate the cameras *less*. if that happened, your correct toe-in would increase the keystoning.
