Flicker Gag
12 replies to this topic
#1 inder mann
inder mann
  • 9 posts
Posted 19 July 2009 - 05:55 PM
i was wondering if anyone knew how to build or where to buy a cheap flicker effect gag/rig
#2 Ross Neugeboren
Ross Neugeboren
  • 110 posts
  • Electrician
  • Greater NYC
Posted 19 July 2009 - 07:24 PM
What are you trying to achieve with the flicker gag?
A number of options exist - there are some special dimmers manufactured by magic gadgets and GAM lighting available with a handful of programs to replicate various flicker patterns.
#3 inder mann
inder mann
  • 9 posts
Posted 20 July 2009 - 01:57 AM
fire flicker and basically random flickering of 2-4 lights.
its for a stylized film so it doesnt need to be motivated.
even 1 or 2 lights flickering would be great.
#4 Ross Neugeboren
Ross Neugeboren
  • 110 posts
  • Electrician
  • Greater NYC
Posted 20 July 2009 - 11:38 AM
Speaking of fire flicker, there's a thread about that right here (Cinematography.com)
#5 inder mann
inder mann
  • 9 posts
Posted 20 July 2009 - 01:07 PM
the only problem with that thread is they're talking about a $450 flicker box
i was wondering if there was anything cheap one could buy or make
#6 Michael Nash
Michael Nash
  • 3330 posts
  • Pasadena, CA
Posted 20 July 2009 - 01:50 PM
...or rent? No one says you have to purchase the item just to use it.
If you want cheap, you get a person to operate each light: either twiddling a simple dimmer or manually waving a small flag or even hands in front of light. Some of my best fire/TV gags have been done by hand.
#7 Ross Neugeboren
Ross Neugeboren
  • 110 posts
  • Electrician
  • Greater NYC
Posted 20 July 2009 - 06:05 PM
Exactly what I was thinking. Adding to this theme - you could do 3 individually dimmed lights with three different cuts of CTO (perhaps 1/8, 1/2, full) dimmed in some sort of offset. Timed right with attentive operators, you could probably get a pretty convincing look.
#8 inder mann
inder mann
  • 9 posts
Posted 20 July 2009 - 08:24 PM
sounds good guys, will do some tests
the dp specifically said he didnt want to use dimmers and flags because they were convinced that it would look cheesy, but i mean, if it works, it works.
thanks again
#9 jeff woods
jeff woods
  • 80 posts
  • Portland, OR
Posted 21 July 2009 - 11:27 AM
Does he mean what it takes would look cheesy, or how it looks on camera? I could see him feeling like this method is "not pro", but ultimately it's the finished product that's the important thing, not how one's ego may be bruised.
2 cents,
-j
#10 inder mann
inder mann
  • 9 posts
Posted 21 July 2009 - 01:28 PM
2 cents,
-j
i think what they did in the past looked bad
but, obviously we'll rehearse and wont make it look cheesy and such
in the end, what ever looks good..
thanks man
#11 robert duke
robert duke
  • 438 posts
  • Grip
  • southeast USA
Posted 23 July 2009 - 11:00 PM
thanks man
There is a cheap way, it can be frustrating to do. Take a pair of squeezers ( in line dimmers) the cheaper the better and plug them in line with one another. adjust the two and voila. You can "find" a sweet spot. It burns up the dimmers in the long run, so use cheap.
#12 Chris Keth
Posted 24 July 2009 - 12:01 AM
If you do this, I find you need one step (1k instead of a 650W, for example) larger light then you think, because the flicker only ever reaches about 60% output.
#13 giap vu
giap vu
  • 42 posts
Posted 24 July 2009 - 12:56 PM
you may want to try this method - used it on a number of features I've worked on: 650 or 1k on a beaver board with 1/2 or 3/4 cto bounced into a bouncing (grip doing the gag) pop-up green screen but shiny side (silver side), or show card. works from wide to ECU.
Edited by giap vu, 24 July 2009 - 12:57 PM.
