Shaft of light using hazer
#1 David Stern
David Stern
  • 5 posts
Posted 06 August 2009 - 03:29 PM
I'm shooting in a giant warehouse trying to create an expressionist in the abyss type of look with a hard shaft of light coming from above and slightly to the side.
In a test, I had a hazer going, with a 650 on my subject.
With my eye it looked great, but the camera couldn't see the haze until I opened the iris way up until my subject was over exposed.
Any thoughts on how to make this work would be appreciated.
Thanks.
#2 Chris Keth
Posted 08 August 2009 - 03:17 AM
Sounds like you need more haze and possibly a light with a harder edge to the beam. You're not seeing it, in part, because the edge of the beam of your 650 isn't all that hard. If there was a hard line there, it would be easier to see. It is also possible, if your actor is light skinned with light wardrobe, that you will have to use 2 different fixtures- 1 for the shaft of light, and one smaller fixture for the talent.
#3 JB_Letchinger
JB_Letchinger
  • 20 posts
  • Los Angeles, California
Posted 12 August 2009 - 08:52 PM
BACKLIGHT the smoke..
that's when it reads
get the biggest light you can --
or try a 1K leco
- yes Chris has a point 2 sources in this case are probably called for.
1 for your shaft :lol:
1 as the key
#4 steve laramie
steve laramie
  • 24 posts
  • Philadelphia
Posted 16 August 2009 - 04:17 PM
A 650 should be sufficient. I would close the barn doors and spot it so its more directional. As long as its a dark background behin the haze it should work nicely.
