EX1 PAL Question
#1 andy schwartz
andy schwartz
Posted 10 August 2009 - 09:29 PM
hey there
i have a steadicam job coming into DC in a few weeks and the client wants to shoot on an EX1 PAL because they are in Ireland. Is there an option on the camera to record PAL and output NTSC? Anyone have any ideas on that. My steadicam is NTSC monitor based, but i could probably find a PAL monitor for they day if need be.
thanks a lot
andy
#2 David Williams
David Williams
  • 69 posts
  • Melbourne, Australia
Posted 11 August 2009 - 03:12 AM
I don't think it can record one while outputting the other.
Are you sure your monitor doesn't auto sense the input? Most modern ones do, my Flyer-LE does.
#3 Brian Drysdale
  • 5196 posts
Posted 11 August 2009 - 04:43 AM
Even the old Steadicam IIIs can change from NTSC to PAL, although you do need a screw driver to adjust the vertical hold.
#4 David Auner aac
David Auner aac
  • 1117 posts
Posted 11 August 2009 - 05:53 AM
Yeah. In B&W that should be the only difference there is IIRC.
Cheers, Dave
#5 andy schwartz
andy schwartz
Posted 11 August 2009 - 07:48 PM
hey
thanks guys
most monitors do both on steadi. the last one i had did not, ntsc only, but i found out that my current one, an upgrade from the older lcd i had, does do both.
so i am good to go!
thanks for the replies
a
