Shellburst film???
#1 Patrick Neary
Patrick Neary
  • 873 posts
  • Portland, OR
Posted 14 August 2009 - 07:44 PM
OK, prizes go to whoever can provide a comprehensive history and uses of this:
#2 Freya Black
Freya Black
  • 4164 posts
Posted 14 August 2009 - 08:07 PM
Well what I can tell you is that Linagraph film was what Kodak used to call it's instrument recording films. Films adapted specially for recording images off CRT screens etc.
However the shellburst film is a bit weird as it appears to be a film for use in military equipment and Kodak described it as being "special characteristics for photgraphing objects against a bright sky".
From what I have been able to find out about it, it basically seems to be a military film for ariel photography of U.F.O's.
Hope that helps.
love
Freya
#3 Patrick Neary
Patrick Neary
  • 873 posts
  • Portland, OR
Posted 14 August 2009 - 08:15 PM
Hope that helps.
love
Freya
Well then that explains why all my shots of UFOs photographed with regular film never turn out!
#4 Mark Dunn
Mark Dunn
  • 2670 posts
Posted 15 August 2009 - 11:52 AM
From what I can work out it's a fairly high contrast red-sensitive film for photographing against a blue sky, which would record clear. Either that, or one lightens the sky with a blue filter. The shellburst, being a bright flash with white smoke, records black. One then makes whatever measurement is required direct from the neg.
During my time at a weapons range we used colour reversal. But then in England, a blue sky was a bit of a luxury.
#5 Rob Vogt
Rob Vogt
  • 437 posts
Posted 16 August 2009 - 12:20 PM
My guess would be "Shellburst" is pretty self explanatory. The military used this to record the aerial-burst characteristics of early ground to air missiles and air to air missiles.
#6 Brian Pritchard
Brian Pritchard
  • 330 posts
  • Rushden UK
Posted 17 August 2009 - 04:06 AM
I had a look through my collection of film datasheets. The closest I could get was Kodak Linagraph Shellburst Film 2476 (Estar-AH Base). This had an ASA of 250. It was a panchromatic emulsion with extended red sensitivity. It had a hardened emulsion for processing up to 130 degrees F, 54.5 degrees C. Development times in D19 were 12 minutes at 20 degrees C to 3/4 minute at 40.5 degrees C. In D76 the times were 7 minutes at 20 degrees and 2 1/4 minutes at 35 degreees C. These times give a contrast of 0.9. The uses mentioned in the datasheet were: Cinetheodolite photography, Spark-chamber photography, Bubble-chamber photography and cinefluorography. It was described as medium speed, medium granulartiy and very high resolving power. The datsheet is dated 4/1975.
Brian
