EX1 oe EX3 with Redrock Micro Encore
7 replies to this topic
#1 Adam Sauermilch
Adam Sauermilch
  • 7 posts
Posted 19 August 2009 - 02:17 PM
Hello All,
I am in the process of purchasing the Sony EX3 as well as a Redrock Micro Encore 35mm adapter.
Question, is there a difference between using the EX1 or EX3 with the REDrock.
When I say difference, I mean difference in quality, just to clarify.
The EX3 is more expensive and when paired together with other accessories like a Matt Box, Shoulder mount, Lenses and extra tape-less media I'm beginning to wonder if it is worth it.
Also, is there another camera with a larger chip and greater image quality around the same price?
Advice would be more than appreciated!
Thanks.
#2 David Williams
David Williams
  • 69 posts
  • Melbourne, Australia
Posted 19 August 2009 - 05:26 PM
The only difference for you would be size and weight, and the potential to use a relay lens on the EX3. The are a handful of relay lenses that work with the EX3, they reduce light loss, increase sharpness, and reduce weight and length.
Without a relay lens, you will see no difference between an EX1 and an EX3.
There is no camera that matches the EX in it's price range.
#3 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 20 August 2009 - 01:40 AM
Hi David,
I notice you now own one, good choice!
Best,
Stephen
#4 John Sprung
John Sprung
  • 4635 posts
Posted 20 August 2009 - 01:42 PM
Yes. The EX3 has interchangeable lenses, so you can mount an adapter on it. The EX1 has a permanently mounted zoom lens, there's no physical way to put a 35mm adapter on it. Or at least that's what I find on the Sony web site: "Lens Mount: N/A" ....
http://pro.sony.com/...product-PMWEX1/
#5 Adrian Sierkowski
  • 7373 posts
Posted 20 August 2009 - 01:57 PM
You can put a lens adapter on the EX1, such as a Letus or Red Rock via a mount that screws onto the front of the lens much like a filter. Of course you'll need a rails/support system to take the weight of the lens adapter off of said screw mount.
#6 Adam Sauermilch
Adam Sauermilch
  • 7 posts
Posted 22 August 2009 - 01:12 PM
Hi David,
Thanks for the info. Question, which relay lenses would you recommend?
-Adam
#7 David Williams
David Williams
  • 69 posts
Posted 22 August 2009 - 04:53 PM
Hi David,
-Adam
I'd go for the Letus EX3 relay, with the Letus Ultimate adapter out of the currently available gear. The P+S Technik Pro35 EX3 looks nice too, but seems to lose more light. The Cinevate still can't be bought, and only B4, and the MotionFX is also still only B4.
http://www.letusdire...-EX3-relay.html
#8 Charles Papert
Charles Papert
  • 36 posts
Posted 23 August 2009 - 03:40 AM
If interested, here is a short made to demo the EX1 and a Redrock M2 about a year and a half ago.
