Affordable S16 zoom lens
12 replies to this topic
#1 konstantin smola
konstantin smola
  • 25 posts
Posted 20 August 2009 - 03:40 PM
I'm looking for an affordable super 16 zoom lens for my Bolex. I have an old Angenieux 15-150 f1.9, but this huge thing got some dust inside… would be too expensive to clean and re calibrate.
What can you guys recommend?
Regards
#2 Rob Vogt
Rob Vogt
  • 437 posts
Posted 20 August 2009 - 07:49 PM
Regards
your cheapest bet may be to get a nikon mount and get a sigma zoom. Like there 12-24 and 23-300 should cover anything you'd really need except maybe a wide shot you might need to find an 8 or 9.5mm
#3 konstantin smola
konstantin smola
  • 25 posts
Posted 21 August 2009 - 04:28 AM
Thanks!
But Im looking for PL Mount Cine lenses…
Prime lenses would also be fine, but I think a set of prime lenses is far more expensive than one zoom lens
#4 boy yniguez
boy yniguez
  • 92 posts
Posted 28 August 2009 - 09:49 AM
Regards
i'd say shoot some footage with it, if anything the dust will just lower the contrast. the angenieux 12-120 was a favorite for a long time!
#5 Fran Kuhn
Fran Kuhn
  • 352 posts
Posted 28 August 2009 - 06:07 PM
Thanks!
Hi Konstantin,
I believe the smallest S16 PL mount cine zoom is the Fujinon 10-40mm T/3.95. This lens was made for the Aaton A-Minima at the request of the Japanese Aaton importer. I don't think there were very many built, but you can check with Abel Cine Tech in Burbank or New York to see if they can find one for you.
You might also consider the Vario-Switar 17-85 T/3.5 Compact Zoom made for the Bolex cameras in C and Bayonet mount versions. It makes surprisingly good quality images for a reasonable price, probably between $500-900. Deiter Schaefer at Procam (Bolex USA) told me recently that this lens will cover S16 throughout its entire range.
-Fran
#6 Saul Rodgar
Saul Rodgar
  • 1682 posts
Posted 28 August 2009 - 10:00 PM
What is your budget?
Is your Bolex PL hard mounted? (with non removable mount?) You don't have a C-mount or a B- mount available? That would be the easiest / cheaper way of going at it.
For a Bolex with C-mount or removable Arri S/ B/ PL mount you could get an Arri S/B-mount later-model Angie 17-68 T2.2. Sharp as tacks and with a Arri S / B- to PL lens adapter you can get a somewhat inexpensive solution if your Bolex is PL hard mounted.
#7 Saul Rodgar
Saul Rodgar
  • 1682 posts
Posted 28 August 2009 - 10:10 PM
http://www.visualpro...ore02.asp?ID=11
#8 konstantin smola
konstantin smola
  • 25 posts
Posted 31 August 2009 - 08:10 AM
Thanks a lot!!!
I did a test shot with the lens at various f stops and focal lengths.
The film is now at the lab. Will get my full HD to Disk scan this week.
I also tested it with the Ikonoskop 9mm lens that came with my a-cam.
In the meantime I found out that leicashop.com here in Vienna could clean and recollimate the lens for about $300,-
I'll keep you guys updated! I will also upload the demo clip on vimeo!
The Bolex got a B Mount! But I will get my SRII converted to S16 and PL mount, so a PL mount lens would be a better solution!
Thanks!
Regards
#9 konstantin smola
konstantin smola
  • 25 posts
Posted 02 September 2009 - 03:32 PM
Hi!
Today I got my HD back, with the dpx files. I converted them into a ProRes QT and edited the file in FCP. I did the cc in Color.
The strange thing is that nearly all of the shots were way too dark! I used my Canon 1D MkII as "lightmeter" - bad choice? Any advice?
But here is the video:
Everything was shot with the Angenieux 15-150, except the last five scenes (9mm Ikonoskop)
#10 David Auner aac
David Auner aac
  • 1117 posts
Posted 03 September 2009 - 01:53 AM
Hi Konstantin,
possible reasons for your footage being too dark on your Rex-5...
1. Partially closed variable shutter. You should see an extremely obvious triangle protruding from the bottom of your finder. You can't miss it if it's there.
2. You set the wrong ISO or shutter on you Canon when metering. You should set it at 1/80th at 24fps to account for the light loss in the beam splitter (you lose around 1/3rd of a stop).
3. Your film was old.
4. There's an ND filter in your behind-the-lens filter tray.
5. Your camera is running too fast.
6. There is something wrong with importing the dpx files. What telecine house did you transfer at? Are they using log or lin LUTs?
That's all I can think of right now...
Cheers, Dave
PS: Oh, and clean that windshield! ;)
#11 konstantin smola
konstantin smola
  • 25 posts
Posted 03 September 2009 - 05:44 AM
Hi Konstantin,
Cheers, Dave
Hi!
1-5: no :)
But yes, probably I've done something wrong when importing the dpx files. Synchro in Vienna. Ahm What? (sorry - Ive never worked with dpx files before)
Here are two unedited screengrabs:
Ps: Sorry for not calling back - Ill give you a call tomorrow afternoon, because tomorrow I have a "Nachprüfung"
#12 konstantin smola
konstantin smola
  • 25 posts
Posted 07 September 2009 - 05:53 AM
any ideas?
Thanks!
#13 David Auner aac
David Auner aac
  • 1117 posts
Posted 07 September 2009 - 05:58 AM
any ideas?
Try changing the dpx file options in your post app. Play around with LUTs...
Cheers, Dave
