square, out of focus highlights
14 replies to this topic
#1 F Bulgarelli
F Bulgarelli
  • 409 posts
Posted 21 August 2009 - 07:34 PM
Hello,
Does anyone know how to obtain this effect?
about 39 seconds into the trailer
It's in the movie "the Sister Keeper"
The car headlights and other highlights appear square
Could be a special iris or maybe just one of those filters with square grids,
any thoughts?
thanks
Francisco
#2 Chris Millar
Chris Millar
  • 1642 posts
Posted 21 August 2009 - 09:28 PM
square iris, yes.
Modify a lens (open it up and replace the iris) or at least on a Bolex both the PTL and POE zooms have a two blade design that will achieve similar effects although oriented 45deg into a diamond shape ...
#3 Jim Hyslop
Jim Hyslop
  • 213 posts
  • 2nd Assistant Camera
  • Toronto, ON, Canada
Posted 21 August 2009 - 09:46 PM
If by "square grids" you're referring to filters like this
then no - those are called star filters.
You can create your own custom bokeh effects. Have a look here.
Jim
#4 Sherman Johnson
Sherman Johnson
  • 10 posts
  • Miami / Atlanta, USA
Posted 21 August 2009 - 09:48 PM
Looks like it's perhaps a hard matte in the matte box... Probably a matte size that's smaller than the diameter of the front element...
#5 Tom Jensen
Tom Jensen
  • 1234 posts
  • Dallas, TX
Posted 21 August 2009 - 10:00 PM
Out of focus practicals?
#6 Chris Millar
Chris Millar
  • 1642 posts
Posted 21 August 2009 - 10:18 PM
Jim
With those you'll get out of focus effects on highlights that should otherwise be more in focus... And in all likelihood would look quite nice, but unpredictable. Basically Im saying that you can no longer trust your lens to operate/focus as you would normally.
By replacing the iris as I have suggested you'll still be able to pull focus and have expected results (to a point) - exposure you'll have to nut out either with a bit of fore-thought or experimentation.
#7 Chris Millar
Chris Millar
  • 1642 posts
Posted 21 August 2009 - 10:20 PM
I think the edges are too sharp for this - but yes its an option huh ;) - time consuming !
#8 Richard Vialet
Richard Vialet
  • 133 posts
  • Hollywood, CA
Posted 21 August 2009 - 11:43 PM
Yea it seems like a hard matte on the mattebox effect.
Aren't there some anamorphic zooms and telephoto primes that have square bokeh like that as well?
#9 F Bulgarelli
F Bulgarelli
  • 409 posts
Posted 21 August 2009 - 11:44 PM
yeah, it might be a square/rectangular iris? interesting
the thing is, they are shooting night which would have required an open or almost wide open aperture
#10 Bruce Greene
Bruce Greene
  • 571 posts
Posted 22 August 2009 - 01:50 AM
I haven't seen the clip, but this is usually caused by a hard matte in the matte box at wide aperture. Try making some mattes in the shape you want and experiment. You can see the effect in the viewfinder. It only shows on out of focus highlights like headlights and such.
It drove me crazy, until I figured it out, when I didn't want it:)
#11 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 22 August 2009 - 02:40 AM
Hey Francisco,
Here's a thread that explains the two causes: http://www.cinematog...hl=square bokeh.
#12 Leo Anthony Vale
Leo Anthony Vale
  • 2010 posts
  • Pittsburgh PA
Posted 22 August 2009 - 01:39 PM
One often sees that bokeh with Cooke zooms.
Because they usually have the square matte at the front of the lens.
usually the 20-100mm, also the 20-60mm & some of the 25-250mm models.
http://www.redrental.....images/zoom2
q=tbn:9dzeGcon91YXtM:http://www.abelcine.com/store/image.php%3Fproductid%3D1001102"]http://tbn2.google.com/images?q=tbn:9dzeGc...uctid%3D1001102[/url]
#13 F Bulgarelli
F Bulgarelli
  • 409 posts
Posted 22 August 2009 - 10:03 PM
Thanks guys, anamorphic zooms, sounds like that's the answer
#14 Nathan Martin
Nathan Martin
  • 61 posts
  • Sydney Australia
Posted 23 August 2009 - 05:59 AM
I was playing around with this effect today actually. The way I do it is to make an additional iris. I cut a piece of black card to sit over the rear element of the lens, then cut the desired shape out of the card and tape it to the back of the lens. If shooting on filM
you will need a bit of testing to check your exposure compensation
#15 boy yniguez
boy yniguez
  • 92 posts
Posted 28 August 2009 - 05:29 AM
Hello,
any thoughts?
thanks
Francisco
hello, francisco,
sherman is correct about the mattebox. it happens when the ac puts an 85mm mask on the mattebox when shooting with a telephoto thinking " hey the angle of acceptance of the 85mm is wider than longer telephotos so it must be fine". WRONG! the diameter of the front element has to be taken into consideration, a smaller mask actually is cutting light that's supposed to enter the outer edges of the lens thus decreasing exposure. since objects very near the telephoto lens disappear, you won't see this cut-offs in the sides of the image, only in the bokeh!
boy
