Help Correctly marking loaded Mags (16mm)
#1 Robert Hawkins
Robert Hawkins
  • 1 posts
Posted 28 August 2009 - 05:07 AM
This is just a quick question.
Can anyone help me with what colour of tape to use for marking different types of filmstock in loaded mags.
As far as I'm aware, for example, 500T would be marked with red tape, 250D with Blue. Is this correct and what are the standards for other stocks.
I am working in the UK if that makes a difference to this practice.
Thanks in advance,
Rob.
#2 K Borowski
K Borowski
  • 3905 posts
Posted 28 August 2009 - 10:49 AM
Thanks in advance,
Rob.
There is no "correct", only conventions. You seem to be on the right track with red for the fastest tungsten stock carried on the shoot and blue for daylight, but this isn't something set in stone.
I always write the NAME of the stock (not the 4-digit code) on the side of the tape too. This [almost] undoes my sloppy handwriting which gets worse in extreme cold or in a hurry ;-)
#3 Chris Keth
Posted 28 August 2009 - 05:36 PM
It's usually something like red for high speed tungsten, orange or yellow for slower tungsten, blue for your daylight stock (If you have 2 you could make them dark and light blue), grey or white for B&W stock.
The important thing is that you stick to your convention (i.e. the convention the 1st wants to use) for the duration of the show. Keep it consistent.
#4 Geovane Marquez
Geovane Marquez
  • 78 posts
  • 2nd Assistant Camera
Posted 28 August 2009 - 07:09 PM
1 more thing I'd like to bring up, do 100 ft rolls come with a spool already?
I think 400 ft don't come with one, but the Lab does give them back right?
#5 Geovane Marquez
Geovane Marquez
  • 78 posts
Posted 28 August 2009 - 07:17 PM
I ment Take-up cores
#6 Dominic Case
Dominic Case
  • 1357 posts
  • Sydney Australia
Posted 29 August 2009 - 07:52 AM
for 100 ft I think you would need a spool, not a core, wouldn't you. i.e. right first time.
Either way, you should be able to get a bagful of these if you call your lab.
#7 Geovane Marquez
Geovane Marquez
  • 78 posts
Posted 29 August 2009 - 01:03 PM
One more thing, I just experienced this for the first time, I accidently didn't tighten up the loop, and the film got all scrambled up, it was a 100 ft B&W double X Negative 250 IE. I fixed it but not sure if my film is ruined. I opened the mag in daylight on set, are just the top perfs on the stock ruined or all of it?
#8 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 29 August 2009 - 02:35 PM
The daylight spools block out most light, but there's probably a few feet on the feed and takeup spools that were exposed and are useless...or artsy/stylish ;)
#9 Tony Brown
Tony Brown
  • 689 posts
Posted 13 September 2009 - 01:03 AM
Weren't late as well were you?
Why are you listing yourself as a Camera Operater if you're actually a very inexperienced loader? Astonishing that you weren't sure how to handle the stock, so you opened it. Didn't it occur to you that that might not be super smart?
