having trouble importing HVX200/tape footage into FCP
#1 F Bulgarelli
F Bulgarelli
  • 409 posts
Posted 09 September 2009 - 10:13 PM
Hello,
We are using FCP 6 and trying to import footage shot on tape with the HVX200 but FCP is not recognizing it.
Any help will be appreciated.
Francisco
#2 Tim O'Connor
Tim O'Connor
  • 860 posts
  • Boston, Massachusetts
Posted 10 September 2009 - 12:38 AM
Hello,
Francisco
P2 footage uses log and transfer but if you recorded to Mini-DV tape with an HVX-200,
are you using straight "capture" ? Check your capture presets; DV NTSC should work.
Have you done this before and it worked and now it isn't? If this is your first go, maybe you just have to choose the right capture and sequence settings. Is FCP seeing the HVX-200? Are you using Firewire, not USB? Is your capture camera on VCR and menu items set up okay?
#3 F Bulgarelli
F Bulgarelli
  • 409 posts
Posted 11 September 2009 - 11:25 AM
Thanks for the reply
I'm wondering if we need to install Panasonics firmware for the HVX eventhough we are doing tape.
#4 Chad Stockfleth
Chad Stockfleth
  • 622 posts
  • Louisville, KY
Posted 11 September 2009 - 12:24 PM
Maybe you have to put it into firewire device mode by pushing and holding the button on the back?
If you take us through what you're doing step by step we may be able to help.
