Question on an adapter or clamp
#1 Perrone Ford
Perrone Ford
  • 8 posts
  • Tallahassee, FL
Posted 15 September 2009 - 10:49 AM
Hi all,
I am looking for something that should be relatively simple.
I have some Manfrotto stands (light stands) that came with my light duty background support kit. The top of these does not have a standard baby pin, but rather has a smaller pin with screw threads.
In that same kit is the following clamp:
While I don't need the background support that often, I do use these stands and clamps as a way to hold flags.
What I am looking for is a clamp or something similar that can do the same job with a baby pin, so I can use c-stands or other light stands without this screw-top fitting. I haven't been able to find anything similar.
Essentially it should just be a basic clamp that has a baby fitting to allow the flag to be vertical. I have clamps that fit in a gobo head, but sometimes I'd be just fine with a clamp right on the head of the stand.
Thanks for any help or info with this.
-Perrone
#2 Michele Peterson
Michele Peterson
  • 148 posts
  • Film Loader
  • Burbank, Ca
Posted 17 September 2009 - 04:24 PM
If I understand you right, you want a clamp that you can fix to either the manfrotto pin or a standard baby pin right?
If that is right, you should look into the manfrotto super clamp. It will accept manfrotto's pin you are picturing. I think it fits a baby pin as well.
#3 Thomas Chaves
Thomas Chaves
  • 16 posts
  • Grip
  • NY, NY
Posted 17 September 2009 - 09:18 PM
Hey dude.
If I understand correctly, here is what you can get:
A Cardellini or Mathellini Clamp
If you would like to hand bounceboards or show car, you can also use a Quaker Clamp (AKA Duck-Bill Clamp)
#4 Perrone Ford
Perrone Ford
  • 8 posts
  • Tallahassee, FL
Posted 27 October 2009 - 08:15 PM
Sorry to be so late on this. I don't really care if the clamp fits the Manfrotto stands. I just want it to fit over a baby pin and give me a clamp. A common cardellini won't do this. It HAS a baby pin on it. I need a clamp that accepts a baby pin.
#5 JD Hartman
JD Hartman
  • 1763 posts
  • Edison, N.J. U.S.A.
Posted 10 November 2009 - 07:16 PM
You're looking for a clamp, like a pelican, that has a baby reciever instead of a pin? I don't see how it would be useful for holding a bounceboard, flag, net or something similar. There would be little or no flexibility in orienting the object held in the clamp jaws.
#6 Perrone Ford
Perrone Ford
  • 8 posts
  • Tallahassee, FL
Posted 11 November 2009 - 12:28 PM
Correct. There would be no flexibility. However, in many instances, when I've got 15 minutes to set up an interview set, simple and fast is welcome. Pop a light stand up, clamp on a bounce board, put up the softbox, focus and shoot. I can toss the clamp(s) in the bag with the stands and have a "fast kit". I realize that this usage won't win any awards, but I am often under serious time pressure to get interviews done sometimes and this would be a welcome solution despite the lack of flexibility.
I guess what I want isn't out there, so I'll just have to find another solution.
#7 JD Hartman
JD Hartman
  • 1763 posts
Posted 12 November 2009 - 03:49 PM
So already owning th clamps which have baby pins attached, you need something to couple two 5/8", baby pin together. Something like: http://www.bhphotovi..._to_Female.html or: http://www.bhphotovi...tor_Socket.html If that's what you need, I can fabricate them for you for less than what Bogen wants. Send me a PM and We can discuss the detaisl.
