bolex aspheron
#1 james mcpherson
james mcpherson
  • 27 posts
  • London, UK
Posted 16 September 2009 - 02:26 PM
i just bought an aspheron lens 5.5mm and the preset switar 10mm lens in some auctions on ebay , to use with my rex5 . can anyone tell me a bit more about the lens, i have no background in film whatsoever and am starting from scratch.. things im keen to know are
A ) do i need any other kind of adaptor to fit it onto the 10mm switar ?
B) was £400 for both a good price? they seem in great condition
C) anyone here use one what are your thoughts?
thanks!
j
#2 David Auner aac
David Auner aac
  • 1117 posts
Posted 16 September 2009 - 03:51 PM
Hi James,
nope. You just screw it on. The 10mm needs to be of the newer, non-waited type. But if it is a preset you're all set. If they are indeed in good condition that is an excellent price! Enjoy your lens! The 10mm is my favorite lens on my Bolex, I don't dig the 5.5 that much though as the vignetting is a little too much for me.
Cheers, Dave
#3 james mcpherson
james mcpherson
  • 27 posts
  • London, UK
Posted 16 September 2009 - 04:30 PM
thanks ! so why do you get the vignetting and i take it theres no way to eliminate that?
#4 David Auner aac
David Auner aac
  • 1117 posts
Posted 16 September 2009 - 04:39 PM
Nope, no way except for zooming into the footage a little in post. As for why I guess it's due to the design of the aspheron. It's a .55 wide angle adapter after all,which is quite bit of a change! And some wide-angles will have light fall-off into the corners no matter what. Many WAs for large format photography have that, the Super Angulons for example. You sue a center filter to cure that in photography though. And you'd loose around 1.5 stops with those.
Cheers, Dave
#5 james mcpherson
james mcpherson
  • 27 posts
  • London, UK
Posted 16 September 2009 - 04:52 PM
thanks Dave and sorry for my dumb questions!
#6 David Auner aac
David Auner aac
  • 1117 posts
Posted 16 September 2009 - 05:26 PM
No problem. And you're welcome!
Cheers, Dave
#7 Phil Savoie
Phil Savoie
  • 94 posts
  • Montana / Wales
Posted 17 September 2009 - 09:21 PM
You are made a good buy the price was fair and the kern 5.5 aspheron was better optically than the 6mm later produced for the 10mm by Century.
