Powerful Dimmer Once Again
#1 smarthdl
smarthdl
  • 2 posts
Posted 26 September 2009 - 05:30 AM
Smart HDL the new leading Manufacturer for Lighting security and home automation in the world have more good news for you For its Powerful Dimmers and relays
Smart Bus Super powerful Dimmers add to its Features good news for all who have problem for connecting the bus lighting system to 110V in such countries like USA, Saudi Arabia and others,
Smart-HDL Product range S-bus Dimmers and relays features:
1. Customizing, same module can work on both 110V, and 220V, no need now to stock 2 different types, make mistake in ordering, or care about installation.
2. Powerful, can dim, ramp the output from 1V-110 V if supplied by 110 V, 1V -220V if supplied by 220V, power Line in from 85-260V AC.
3. Standard, work in both 50 HZ and 60 HZ, Auto detecting Technology.
4. Green, operated by the bus network 24V supply, Operation consumption for the 8 channels Relay, Just 12mA/24VDC.
5. Protection, all Dimmers have built in temperature sensor for overheat protection, with big heat sink, with overload, and surge Protection for both power line and signal line..
6. Smart & Elegant, small and din rail, with channel momentary button operated, Life LED indicator, Broadcast address function, Elegant plastic Labeling Area.
7. Functionality, Channel Maximum Level setting, minimum Dimming Level, Safety Delay time option, channel name and load type remarks, Scene and Area Settings, Sequence programming for Disco show or Industrial applications, Power On Module default safety scene setting.
8. All Options, for all installation needs, for Din Rail Rang,
• Dimmer 6 channels 2 Amp
• Dimmer 4 channels 3 Amp
• Dimmer 2 channels 5 Amp
• Relay 8 Channel 16 Amp
• Relay 8 Channel 10 Amp
• Relay 4 Channel 10 Amp
• Relay 4 Channel 20 Amp
• Curtain 2 Change over Relays for 2 curtains.
For more info, Manuals, Films and others you can visit our website http://www.smart-hdl.com
For installation and Programming Film you can visit http://www.youtube.com/sbustraining
Edited by smarthdl, 26 September 2009 - 05:32 AM.
#2 David Rakoczy
David Rakoczy
  • 1579 posts
  • USA
Posted 26 September 2009 - 08:00 AM
smarthdi,
Per the rules of this Forum,
Please go to My Controls and change your screen name to your real first and last name.
The Members thank you in advance.
