Transfer Telecine Systems
#1 Geovane Marquez
Geovane Marquez
  • 78 posts
  • 2nd Assistant Camera
Posted 29 September 2009 - 11:02 PM
I've come across what looks like a Film to Video Tape transfer
http://cgi.ebay.com/...34.c0.m14.l1262
Is it for real though? I mean it's way too cheap compared to Telecine Houses.
It's a Kalimar Film To Video Transfer System
Sht if this is Legit , Ill transfer all process film into this
#2 Steve Phipps
Steve Phipps
  • 59 posts
Posted 30 September 2009 - 01:38 AM
Hi.
I don’t know that particular device, but it looks similar to the Goko TC-20, which is (relatively more) well-known and is indeed a “legit” transfer device.
I watched a transfer session (of Super-8) done through a TC-20 with results that looked excellent. I’ve seen transfers (of Super-8) that claimed they were done through a TC-20 that looked awful. Center-spot brightness, flicker, and fuzzy resolution. I’ve never used the device myself, so I can’t tell you what goes into a successful transfer.
By the way, I could say the same things about simple wall-transfers. I can recall seeing results that looked excellent. I’ve seen some that looked awful.
#3 Matthew W. Phillips
Matthew W. Phillips
  • 1792 posts
Posted 30 September 2009 - 02:07 AM
I used one of those boxes before and you'll get decent results if you have a 3ccd camcorder and set it up for perfect focus. Problem with this method is: You can only do a certain frame rate capture with this without getting flicker. I had a Chinon variable speed projector at the time and I got something like a 15 3/4 fps rate to avoid flicker. Therefore, if you're doing dialog stuff at 24fps, it wont sync right. I posted my short film "The Wheat and the Chaff" under the "Please critique my work" section and the opening credit stuff with my daughter and the cats playing was transferred using one of those things. The slow frame rate and soft focus look gave a chilling old-school home movie appearence. The rest of that film was a RANK transfer @ 24fps from Debenham Media Group who I highly recommend and their prices are cheaper than any RANK house I've ever seen.
#4 John Sprung
John Sprung
  • 4635 posts
Posted 30 September 2009 - 12:46 PM
It's kinda like buying roller skates versus renting a Rolls-Royce. They both get you there, but at different price/performance points. Do you have enough film, or transfer film to tape often enough, that you'd want to own such a thing and find closet space for it?
