Red
#1 Gareth Munden
Gareth Munden
  • 137 posts
  • London UK
Posted 07 October 2009 - 04:10 PM
Hello everyone.
I have a shoot coming up on the Red. It's all day exteriors and for some reason or other I wanna shoot without a matte box and hence no NDs and add to shooting at T2ish. So the question is how low can I rate the ISO on the Red and what happens ???
#2 John Sprung
John Sprung
  • 4635 posts
Posted 07 October 2009 - 04:50 PM
I've heard of people rating it as low as 160. But watch your histogram and false color on the camera. Red is kinda its own light meter in that way.
#3 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 08 October 2009 - 02:21 AM
The lower you rate the ISO, the less exposure headroom you will have. The camera sensor's nominal rating is 320 ISO, so if you rate at 160, you will have 1 stop less range in the highlights. DP Art Adams suggests the sensor has 3.5 to 4.5 stops of overexposure range under 5500K and 320 ISO: http://provideocoali..._torture_tests/.
That might be okay if you can control your highlights with silks and such, but most day exteriors will have highlights well over that. So by rating the camera at 160, you will only have 2.5-3.5 stops over middle grey before clipping. That's not much, a white shirt under flat, soft light will be 2 stops over.
You can always tape flat NDs to the lens in a pinch, or use drop-in rounds in a metal clip-on shade, or tape a bellows with a 138 back to the lens. Or just cut the shutter. Lots of options.
