SonyDigiBeta VERSUS PanaSDX900
#1 ricardo de gracia
ricardo de gracia
  • 21 posts
Posted 29 October 2009 - 04:43 AM
what would you say is better choice for a TV docu series similar to typical discoverychannel docs? or TV series Dog Whisperer?
* no chances for hi postproduction or color correction
* no filtering on camera...
wich one is more sensitive? better quality? best latitude in hard light situations? noise...?
THANKS IN ADVANCE
#2 Brian Drysdale
  • 5197 posts
Posted 03 November 2009 - 04:51 AM
The DigiBeta is a tape format used by range of cameras, so it'll depend on which model you're going to shoot on. The cameras I've used on this format have a "cleaner" look than the SDX900, which has a different feel.
The SDX 900 has a selection of gamma setting as do the later Digibeta Cameras, so much will depend on which setting you select to use.
DigiBeta is 10 bit compared to the 8 bit on the SDX900. If you wish to shoot progressive the SDX900 can do that while you need the DVW970 for DigiBeta.
Basically, both cameras will do the job and Digibeta has been used for years without high end post production or colour correction. Although, if you wish to create an interesting look in camera the SDX900 could be the way.
Also, talk to your post house which works best for them, they may have to hire in rather than use an in house VTR.
#3 Chris Burke
Chris Burke
  • 1722 posts
  • Boston, MA
Posted 11 November 2009 - 10:24 AM
unless you are getting a special discount or otherwise, is the cost of shooting digibeta that much cheaper than HD? if it is for your situation, then shoot on digibeta, it being 10 bit makes a difference, especially if it is to be uprezzed later on to HD.
#4 Brian Drysdale
  • 5197 posts
Posted 11 November 2009 - 11:41 AM
I guess that would depend on which HD camera you plan to use. Certainly much cheaper than shooting with HDCAM cameras, not if you're going EX1/3 I suspect.
