7D resolution vs sony EX 3
80 replies to this topic
#1 Bobby Shore
Bobby Shore
  • 95 posts
  • Los Angeles / Montreal
Posted 30 October 2009 - 01:45 PM
hey,
just curious, would the sensor size of the 7D have better resolving power than the sensor size of an EX 3? I guess in theory I'm thinking yeah (the same way 35mm resolves better than 16mm), but since both the 7D and the EX 3 shoot native 1080P HD, would the sensor size necessarily make that big of a difference?
I've tried researching, but haven't really found anything too concrete. Thanks in advance for any input.
bobby shore
www.bobbyshore.com
#2 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 30 October 2009 - 02:23 PM
The BBC allow the EX1/3 to be used on SD productions, the 5D is not considered acceptable to the BBC for SD Production.
hey,
bobby shore
www.bobbyshore.com
#3 Bobby Shore
Bobby Shore
  • 95 posts
Posted 30 October 2009 - 03:23 PM
hey stephen,
thanks for the reply... for me it's more a question of whether or not the 7D could serve the shoot well for some of the wide shots we're planning. We're planning on finishing to film (which will probably be the next thread I start - EX 3 filmout), so I'm curious if the larger HD sensor would actually better resolve fine detail.
I've found some info for the EX at 1000 TV|/ph, but nada on the 7D.
bobby
#4 Adrian Sierkowski
  • 7373 posts
Posted 30 October 2009 - 03:41 PM
Depends on the type of film you're out to make. Do you need the shallower DoF of the 7D. Can you work within the limitations of the 7D and/or the EX3? Sensor size alone isn't really the way to compare cameras. A 7D might be great for run and gun documentary shooting where you want to hide your video camera, but on a narrative set the EX3 with it's "known" workflows and the fact that it's built like familiar video cameras (and hence can take their accessories easier) might be useful. Or maybe you need to shoot a 45 minute interview-- then you'd have to use the EX3. Or you're planning on just a series of short shots and you can get away with the 7D (which I think has a recording size limit). Or you are in some ugly locations and need to throw the backgrounds out of focus and need the DoF of the 7D.... so many variables. A little more information on the project and the aesthetics you're looking for would be helpful.
#5 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 30 October 2009 - 04:12 PM
I just bought a 7D and have been shooting with it for the past two days. It is soft at 1080 24P, certainly softer than the EX3. Playing it back on a 50" 1080P plasma HDTV via HDMI and on a 23" Cinema Display in Quicktime/FCP.
I think it would be acceptable downconverted to 720P, certainly all the 720P footage I've seen from the camera on Vimeo has looked sharp. The camera also does not have much dynamic range - it blows out quickly and clips hard in a nasty video-y way, and the noise floor is definitely there in the lower third of the histogram. I'd stay at 800 ISO or under and protect highlights, 1000 ISO is definitely pushing it. The 5D footage I've shot looks sharper with better dynamic range - it has a bigger sweet spot out of the box. Both cameras have some banding in out of focus areas. I was also not able to get rid of tv flicker even with a 1/60 shutter. Have not encountered any fluorescent flicker yet.
Frankly, I think the 7D is great for web and standard def distribution, but I'd hesitate to use it for anything going back to film and the big screen. We have to be realistic - for $1,700 you're still getting a lot of camera, and it's fun to shoot with. It is surprisingly difficult to focus (depends on your lenses, of course) and to keep the image stable in handheld. Keep in mind how big your final output will be and slow down your camera movements accordingly.
#6 Rob Vogt
Rob Vogt
  • 437 posts
Posted 30 October 2009 - 04:24 PM
I spoke with a man from Frontline PBS at the HD World convention a couple of weeks ago. He was talking about the 5dII and he said that they wouldn't recommend it to their field ops simply because it was tapeless. They aired footage from a 5dII because the stuff this freelancer in Afghanistan got was amazing, but they said they would stick with HDV or other non-tapless cameras. I'm assuming that would be the BBC's position on the 7D, unless they ruled the 5D2 fit for SD productions.
#7 Peter J DeCrescenzo
Peter J DeCrescenzo
  • 620 posts
  • Portland, OR, USA www.peterdv.com Blog: http://herefortheweather.wordpress.com/
Posted 30 October 2009 - 04:40 PM
The video resolution of the Canon 7D (and most likely the 5DM2, too) is considerably less than the Sony EX1 & EX3.
See Barry Green's trumpet chart tests on DVXUser.com:
http://www.dvxuser.c...ad.php?t=186334
The Panasonic GH1 fared a tiny bit better than the 7D, but its video isn't nearly as good as the EX1/3:
http://www.dvxuser.c...ad.php?t=187165
However, it's interesting how -- despite these "DSLR" cam's relatively poor technical performance -- they are capable of producing fairly pleasant-looking HD video when handled appropriately. There are many examples of this available online.
But the chart tests don't lie: The actual video resolution of the 7D, GH1 & 5DM2 is quite low compared to most other HD video cams.
#8 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 30 October 2009 - 06:14 PM
The BBC don't accept the 5dMKII for SD broadcast due to aliasing. Alan Roberts who tests all cameras for the BBC wrote:-
'Yes, I have done formal tests on one and found out just what it does. 30Hz is a problem, but not the most significant one (the spectacular spatial aliasing, which makes it very difficult to compress well for broadcast at a sensible bit-rate). Canon have told me that the model they supplied for test was the version to be sold. So it gets a thumbs down for broadcast use'
#9 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 31 October 2009 - 07:35 AM
Update re: nasty video-y clipping.
I've started netting the back of all my primes to take the curse off the hard clip, and it's made a huge improvement in the look (while probably doing terrible things to "real resolution", but who cares about that!). The softening effect is in between a 1/8 and 1/4 BPM with nice halation and a creamy, more filmic texture. I'm curious what effect (if any) this will have on aliasing. Anyone know?
#10 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 31 October 2009 - 08:14 AM
Should help reduce it.
#11 Paul Bruening
Paul Bruening
    (deceased)
  • 2858 posts
  • Oxford, Mississippi
Posted 31 October 2009 - 11:16 AM
What goes on with video engineers? It seems they think in terms of what we will compromise for when they design these widgets.
How many stream processors would it take to run the whole 5D or 7D sensor without compression at 24 fps? How many UDMA's at once to take the whole sensor in actual uncompressed bits with an internal clock to sync them all to when you dump the data to computer.
#12 Matti Poutanen
Matti Poutanen
Posted 31 October 2009 - 01:44 PM
What did you use for netting the lens?
#13 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 31 October 2009 - 04:35 PM
Thanks Stephen.
I use Berkshire Ultra Sheer nylons in Fantasy Black color. I did a lot of testing back in January for a 35mm shoot, and these were the ones I liked best. They looked great on the big screen in 35mm, and were surprisingly subtle. They cost around $7 a pair! Stretch it across the back element and attach it with some snot tape (3M Scotch ATG tape).
I did not test pure silk since I could not find any in my area, and it is super expensive online. The Berkshires give a 4 star cross pattern on highlights (which I could do without), and also create a rainbow diffraction around highlights (which I like). They do create a significant amount of halation.
#14 Brian Drysdale
  • 5195 posts
Posted 31 October 2009 - 04:53 PM
I suspect the stills market wouldn't want to pay for these processors. The system seems to have been developed for photojournalists to provide video for the news web sites, which it does just fine.
#15 David Mullen ASC
  • 20072 posts
Posted 31 October 2009 - 06:59 PM
hey,
bobby shore
www.bobbyshore.com
Well, the larger sensor of the 7D (which is Super-35 in size I believe, i.e. APS-C, not FF35 like the 5D) would mean that a lens could have a lower MTF and still capture fine detail compared to a smaller sensor with a sharper lens. However, the 1080P recording is a limiting factor to some degree, not to mention that the way that the Canon still cameras create 1080P involves tricks like line skipping (and the OLPF was not really designed for this), not to mention the compression scheme used, so you aren't necessarily getting the maximum potential resolution from the sensor anyway. However, there will be a difference in Depth of Field between the 7D and the EX3 unless you compensate with the f-stop, and shallower-focused images often give the illusion of looking sharper because only the subject is in focus relative to a soft background.
#16 Bobby Shore
Bobby Shore
  • 95 posts
Posted 01 November 2009 - 02:21 PM
David, thanks the reply. I guess there's a lot more to consider than just the sensor size. I was able to filmout both footage from the EX 3 and 7D, but unfortunately it couldn't be a side by side comparison. If I can swing it, I figure the best way to actually answer this question would be matching wides blown-up to film. If I can get production on board, I'll post the results.
@ everyone else - thanks for all the info and advice, much appreciated.
bobby
#17 Tom Lowe
Tom Lowe
  • 1211 posts
  • somewhere worshipping Terrence Malick
Posted 01 November 2009 - 08:04 PM
The Canon vDSLRs are not 1080p cameras, period. Maybe 720p, but even then you are subject to horrendous aliasing if you point it at the wrong subject.
#18 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 02 November 2009 - 02:47 AM
Hi Tom,
Reminds me of a 4k camera!
Stephen
#19 Tenolian Bell
Tenolian Bell
  • 907 posts
  • Brooklyn, NY
Posted 02 November 2009 - 11:28 AM
PBS’s Frontline, one of the most beautifully shot and edited documentary programs on television, produced segments for it latest show Obama’s War with the Canon 5DmkII. One of the DP’s, Danfung Dennis , shot the opening sequence with a custom rig that allowed it to be attached to a steadicam rig.
Frontline Shoots Doc with Canon 5DmkII
#20 Tenolian Bell
Tenolian Bell
  • 907 posts
  • Brooklyn, NY
Posted 02 November 2009 - 11:30 AM
Are they less 1080P cameras than previous HD cams that shot 1440P with 2/3 inch sensors?
