2k gamma correction
#1 Fulgencio Martinez
Fulgencio Martinez
  • 164 posts
Posted 15 November 2009 - 04:46 PM
I shoot a S16mm feature in morocco
It was scanned to 2k and did a grading for film printing at technicolor London
Now the director has this grading, and has done some DVD with it
As it was graded to be Filmout it is not right in gamma on the PAL dvd... black is not 0 white is not 100 ire
So.. Could i apply a gamma correction over the 2k files on a mac pro to make a dvd,bluray properly??
what software is the best for this? fcp color?
thanks in advance
Fulgencio
#2 Phil Rhodes
  • 12168 posts
Posted 15 November 2009 - 06:24 PM
I'm not quite sure if I understand what your situation is.
Do you have the graded 2K data files? Are you making DVDs and blu-ray discs from those? What software are you using to do that? Do the 2K files look OK?
If you are seeing white and black offsets in your DVDs that could be caused by a lot of things and it's hard to be specific. Yes, you probably could fix that sort of thing in Color, but you should probably contact the place that graded it for advice too.
#3 Fulgencio Martinez
Fulgencio Martinez
  • 164 posts
Posted 15 November 2009 - 09:19 PM
The producer/director has the 2k data files in a hard drive
they looked great at technicolor, but i guess there was a 3d Lut to make it look like the final 35mm copy.. wich was never done due to money issues
#4 Elliot Rudmann
Elliot Rudmann
  • 208 posts
  • Chicago
Posted 16 November 2009 - 10:20 AM
They probably just didn't "bake" in a LUT when they rendered out and gave you the files, which is why they look flat. I would contact them ASAP and hope they still have the files on their system. Otherwise you could try applying a basic LUT of your own, although you may not be able to accurately reproduce what it looked like @ Technicolor without using their LUT(s). To be honest, this is probably something a skilled colorist should handle, as trim-pass color grading (for 35mm print) is different than grading for video distribution.
