What is a Distro Box?
#1 Nick Centera
Nick Centera
  • 88 posts
  • 2nd Assistant Camera
  • San Diego
Posted 15 November 2009 - 05:44 PM
Hey, what exactly is a distro box? Why would you need to use it and when would you use it? Thanks
Nick
#2 John Hoffler
John Hoffler
  • 132 posts
  • Film Loader
  • New Orleans, LA
Posted 15 November 2009 - 08:26 PM
a distro box is a 600 or 300 amp breaker box that takes power from a generator or house power via camlocks and breaks it off into separate 100amp outputs for running power to all the lights you need.
you'd usually run 100amp or 60amp whips off the distro out to your lunchboxes (smaller power boxes which splits that 100 amps down into 20amp edison plugs) or directly into the larger lights that require higher amperage to run.
basically each box simply breaks the overall power of your genny/house power into smaller, and more manageable plugs.
hope this helps :)
#3 Nick Centera
Nick Centera
  • 88 posts
  • San Diego
Posted 20 November 2009 - 10:11 AM
That makes much more sense now, thanks! If you running off a house, where would the distro get wired into? So that it gets all or most of the power from the house.
Nick
#4 Brandon Whiteside
Brandon Whiteside
  • 62 posts
Posted 21 November 2009 - 02:46 AM
the distro gets wired into the house.
#5 Dan Salzmann
Dan Salzmann
  • 1143 posts
  • Paris, France
Posted 21 November 2009 - 06:49 AM
By a qualified electrician!
#6 timHealy
timHealy
  • 1262 posts
Posted 21 November 2009 - 05:36 PM
Nick
For clarification "the house" refers to the place one is shooting. It could be a building, it could be a stage, it could be an actual residential house. All are referred to as "the house". Usually if one is working with the maintanence guy, or electrician for the building, he is referred to as the "house man".
Best
Tim
