animation on a bolex
#1 Alina Postula
Alina Postula
  • 4 posts
Posted 18 November 2009 - 11:28 AM
I am going to be doing a stop motion animation on a bolex (rex 5 I believe). I was told that I should either get a motor or set it to 12 fps and meter for a 1/40th of a sec shutter speed? But I'm a little unclear on it if anyone could clarify this for me it would be great. thank you.
#2 Bernie O'Doherty
Bernie O'Doherty
  • 232 posts
  • Newark Valley, NY
Posted 18 November 2009 - 11:43 AM
You really should set the I/T lever to I (intermittent). Then push the Stop/Go button Toward the Lens. This will give you a single frame image each time you push the button forward ( it's on the side of the camera). Exposure is rated at 1/30 th of a second. Good Luck.
#3 Tom Hepburn
Tom Hepburn
  • 341 posts
  • Chicago-land
Posted 18 November 2009 - 02:39 PM
Also, I'm not sure if your camera has one, but if it has a cable release, I would use it. Nothing worse that doing all of that work only to find out that the camera moved ever so slightly each frame as a result of pushing a button on the side.
T
#4 Chris Millar
Chris Millar
  • 1642 posts
Posted 19 November 2009 - 01:41 PM
They may have meant "get a motor and set it to 12 fps" ...
However, use a cable release as has been suggested.
I bet you'll be bookmaking this website:
http://www.sci.fi/~animato/
The 1/30th 1/40th issue is a confuddling mess of misinformation due to the prism (or lack thereof) - are we talking of a real time or an 'adjusted for the prism' time - and on top of that different cameras single frame 'T' settings give different times depending on the stickiness in the system (like the bell thingy in the governor).
