Lighting Car interior Daytime
12 replies to this topic
#1 andrewzp
andrewzp
  • 1 posts
Posted 18 November 2009 - 07:22 PM
Hello; i'm shooting a car interior, front two seats with two subjects during the day and wanted to know what kind of light would suffice. Obviously, there's the sun but it constantly moves throughout the day and of course, the car interior provides a lot of shadows.
As we're going to be out in the field would certain battery powered LED's (within spending range -- tried the litepanel micro.. It was too weak) or flourescents be powerful enough during the day to add some consistent illumination to the face?
Or, if you have a better solution please let me know.
Thanks!
#2 timHealy
timHealy
  • 1262 posts
Posted 21 November 2009 - 05:48 PM
Thanks!
Car rigs are usually done with a tow or towed rigged platform, so one can use lights and the actors can concentrate on acting and not worry about driving safely. If you are having your actors drive the vehicle they must be able to see the road and not have their vision obscured by lights and cameras. Having said all that. If you go that way keep it simple and safe. I did this once on a closed road and had a white sheet taped to the hood. If you are not going through the shadow of trees the exposure can be consistant. if you are doing the low budget method you can expose for their faces and let the background go, but it may really go! You can wait for earlier or later in the day where the sun is low and hitting the actors face and the back ground won't be blown out. It depends on what your resources are in terms of money and rigging and manpower.
best
Tim
#3 JD Hartman
JD Hartman
  • 1764 posts
  • Edison, N.J. U.S.A.
Posted 29 November 2009 - 12:39 PM
A small 12V inverter, the type that plugs into the cig. lighter will give you 300w of 120 power. Thats enough for a few small Kinos or hardware store strip lights with color corrected tubes. The biggest issues, as already mentioned are safety and balancing the difference in exposure betweeen the outside and the inside of the vehicle. Driving away from the sun is a good idea, otherwise you might consider blacking out the hood with temporary hair dye, like Streaks and Tips (or is it Tips and Streaks?).
#4 Adrian Sierkowski
  • 7373 posts
Posted 29 November 2009 - 12:43 PM
Streaks and Tips, I think.
The inverter/Kino idea is a good one to get some light in the car , they have some high output for their wattages and are daylight balanced. Or, you can try doing all of this on a green screen stage.. but it's not something I'd really want to do.
Also, shooting format will help dictate how much you need to light. I've shot in plenty of cars on S16mm with not supplemental lighting because the stocks can handle the over-exposure outside pretty easily. Also, picking the area helps a lot too, like say a downtown where you have a lot of building shadows giving you a pretty even exposure, or a shady street etc.
#5 Karel Bata
Karel Bata
  • 487 posts
  • London - a rather posh bit
Posted 29 November 2009 - 05:48 PM
I'd be very wary of running 300W of lighting from a cigarette lighter socket! I've no idea what the max rating is, but 300W sounds at bit excessive. Last thing you want is a fire!
If I were going this route I'd run run some heavy cables direct from the battery to the inverter, and properly wired in, not just croc clipped. And don't switch the lights on until the engine is running or you could get a flat battery!
#6 Adrian Sierkowski
  • 7373 posts
Posted 29 November 2009 - 05:51 PM
IIRC 150W is the max standard for a typical lighter; though personally I've never gone over 100...
#7 Alex Haspel
Alex Haspel
  • 282 posts
  • vienna, austria
Posted 29 November 2009 - 06:43 PM
theres 12 to 220v converters that can be plugged directly to the battery.
on my last feature we often powered a 200w hmi with it, enough for an overcast day.
good converters should also be able to handle a jokerbug or some other 400w hmi.
#8 Adrian Sierkowski
  • 7373 posts
Posted 29 November 2009 - 09:06 PM
I have a 400W and a 1500W inverter, but those need to go on the batts as you mention. For a cigarette outlet, 100 is the safe bet, but I'm pretty sure you can go up to 150 depending on the fuses/wiring in the car.
#9 Karel Bata
Karel Bata
  • 487 posts
Posted 01 December 2009 - 08:47 AM
A good converter is the key here. A 12V battery will give a nice even supply, but once you have the car engine running you will get some horrendous spikes. A good converter should iron these out. A cheap one may well cause damage to the circuitry in an HMI. Wouldn't be an issue on incandescent bulbs though.
I'd use a converter rated slightly higher than the light you plan to use.
#10 Reinis Traidas
Reinis Traidas
  • 15 posts
  • Melboure, Australia
Posted 07 December 2009 - 11:23 PM
I've used small LED Litepanels in the past. If you're getting single close-ups or medium shots of either actors you can easily use folded gaffer tape to attach a thin litepanel on the bottom of a sunscreen. This will give you fairly good, soft and filling illumination on the actor's face and will help you keep the background from blowing out. These things can plug into a cigarette lighter. You may need to try and conceal the cables somehow too. Again - if you're getting close-ups then it's a relatively easy, quick and inexpensive option. If you want a 2-shot then you might need to put the car on a low loader or platform. The LED's aren't very bright (although there may be brighter ones available now) but as far as I remember they will give you at least 1 or 1.5 more stops on your incident reading near the face.
#11 JD Hartman
JD Hartman
  • 1764 posts
Posted 08 December 2009 - 12:24 AM
I've yet to see lighter circuit that wasn't fused for at least 20a, that would give 240w before the fuse element begins to warm up. So small Kino(s) would be no problem in an auto interior.
Check.....,don't guess.
Edited by JD Hartman, 08 December 2009 - 12:25 AM.
#12 Daniel Carruthers
Daniel Carruthers
  • 334 posts
  • Canada
Posted 08 December 2009 - 01:59 PM
I'll sometimes use ND gel on any window that is on camera
I did a side cu shot of a driver from the passenger side and the window behind the driver was blown right out
it was mid afternoon which made it really hard
so I put some nd9 on the one window,but I left all the other windows ungelled that where off camera
I was able to exposed for the shadows and the background held up fairly well
especially considering I shot it on a 1/3 chip camera
I didnt use any lights what so ever, oh but I did put a white sheet in the actors lap
he didnt mind:) but that created some good bounce light at times
#13 Vivek Marimuthu
Vivek Marimuthu
  • 14 posts
  • Singapore
Posted 22 December 2009 - 08:11 AM
I had done a night shot and used LED panels taped to the dash board and glove box. Infact, I opened the glove box and taped a led panel inside it and one on the cover of the glove box.
If I were to attempt to light the car, I would first check the direction of the car's movement - n/s/e/w. Depending on budget, I would either go in for a towed rig platform or use Kino inside the car and power it up using the car cigar lighter panel...
Vivek
