using double 8mm film in a 16mm camera?
#1 chris hoag
chris hoag
  • 17 posts
  • Chricago
Posted 24 November 2009 - 09:56 PM
i just shot some double 8mm plus-x reversal (that i broke down from a 400ft) roll in a 16mm camera and the image looks a bit jittery. should double 8 perf film not be used in 16mm camera? will it cause registration problems?
thanx,
chris
#2 Ed Sieb
Ed Sieb
  • 53 posts
  • Ottawa, Ontario
Posted 24 November 2009 - 10:19 PM
Theoretically should work. The only issue I can think of is that the extra perfs may be causing a jittery loop? What camera did you use it in?
#3 chris hoag
chris hoag
  • 17 posts
  • Chricago
Posted 24 November 2009 - 10:37 PM
arri s
#4 John Sprung
John Sprung
  • 4635 posts
Posted 25 November 2009 - 02:41 PM
Ask Tim Carroll, he's the Arri S expert. Post in the Arri forum under "Cameras and Formats" "16mm"
#5 Bruce Taylor
Bruce Taylor
  • 482 posts
Posted 25 November 2009 - 07:29 PM
I know little about Arris, but I am pretty sure the perfs and the concept should present no problems. When I was a kid I regularly projected and edited my 8mm movies on 16mm equipment without problems (other than everything goes by twice as fast!). I borrowed the 16mm gear from the AV closet at school because I couldn't afford a projector or editor (paper routes pay poorly).
I use the same principle with 2 perf 35mm. You can project a 2 perf workprint on any 35mm projector, the images will just be half as high and go through twice as fast. Good enough to check critical focus or other issues.
Bruce Taylor
www.indi35.com
#6 Jim Carlile
Jim Carlile
  • 464 posts
Posted 27 November 2009 - 02:27 AM
A 400 foot roll? How old was it? Was it Kodak, or a plain label? It might have been re-perfed 16mm, which would explain the jitter-- the perfs weren't up to snuff.
Kodak R8 won't have any problems, except in threading the projector, where you might start with a split-frame in the gate due to not knowing where the perfs line up.
