flashes of blue on film?
#1 Daniel Carruthers
Daniel Carruthers
  • 334 posts
  • Canada
Posted 08 December 2009 - 04:06 PM
Hi I recently saw some Ultra16mm footage I shot last summer
it was a test for a wedding video company looking to offer 16mm film to their clients
I shot about 50 feet of fuji 250t it was a 4 month old recan from a short film I shot earlier in the year
Anyways the film didnt get processed right away it sat in a fridge for about 3 months then the wedding video company got around to getting it developed and transferred a few weeks ago
it was transferred at pro res 422hq 1080
Anyways when I was watching it, every couple of seconds the image would flash blue
then disappear
Does anyone know what this could be?
At first I thought maybe I accidently flashed the negative when loading, but I know I was real careful, and I always thought when that happend you get red flashes not blue?
any ideas? could it be that the film sat un-processed for 3 months or maybe something happened at the lab or transfer house?
#2 Richard Tuohy
Richard Tuohy
  • 482 posts
  • Daylesford, Australia
Posted 08 December 2009 - 05:20 PM
then disappear
Hi Daniel,
it is very possible that condensation got in while the film was in the fridge after shooting. If a film gets wet in this way, when the film is un-wound prior to processing static flashes can be generated as the wet film peels off from the wind. I think these are typically blue. A fridge is a very humid environment. When you buy film from kodak, you can be sure that the film container is air tight and that the tin was packed in a humidity controlled environment. In that state, it is safe to put in the fridge. After shooting, however, this is no longer the case. I wouldn't store exposed film in a fridge for this reason.
regards,
richard
#3 John Sprung
John Sprung
  • 4635 posts
Posted 08 December 2009 - 07:34 PM
Can you post some frames? Static electricity flashes can look different than moisture damage.
#4 Bernie O'Doherty
Bernie O'Doherty
  • 232 posts
  • Newark Valley, NY
Posted 08 December 2009 - 07:52 PM
Could be a light leak. Make sure your eye is against the eyepiece rubber. Tape the mags. You might want to do a light-leak test by shining a light all the way around the running camera with film. Time it so that each quadrant of the lighted circle is 5 secs duration. This way you could figure out the leak source.
Another way would be to put a 9volt battery with bulb attached inside the magazine and go into a darkened room. Slowly manipulate the magazine in all directions while looking for any light exit points. Light coming out means light's going in.
#5 Daniel Carruthers
Daniel Carruthers
  • 334 posts
  • Canada
Posted 09 December 2009 - 03:51 PM
Thanks for the info
I'll see if I can get some footage to post online
#6 Adam Garner
Adam Garner
  • 95 posts
  • Austin, TX
Posted 09 December 2009 - 07:47 PM
I had a weird cyclical flash on some 500T recently. It wasn't blue, but it looked like the film was overexposed back and forth. It was weird, and I asked some folks about it that thought it could have been a roller. No one had seen it.
I keep 100' rolls in the fridge and I got to thinking, they're not sealed like Super 8 carts are. They're only wrapped with that paper ribbon inside a plastic box.
Is it possible that 16mm film in the fridge can get humidified?
Also, the day I shot that footage it was ridiculously humid, summer in Dallas/90 degrees and raining. So bad that my lens would fog up any time I would pull the camera out.
I wonder....
