Bungee Cam Rig
15 replies to this topic
#1 Tim Nuttall
Tim Nuttall
  • 23 posts
  • New York, NY
Posted 13 December 2009 - 03:09 PM
Hi all,
Looking to build a bungee cam rig on a Fisher 11 Dolly to hold an Arricam Lite. Probably can't get something smaller like a 235. Has anyone done this? Would like to cross the bungees in an "X." Thoughts on construction?
#2 ian mussell
ian mussell
  • 15 posts
  • Grip
Posted 13 December 2009 - 11:44 PM
Hi all,
hi tim,
i've done this a bunch of times, simplicity is the best way! i use a spreader bar on top wide enough to keep to bungees away from the camera body. on the bottom plate use solid stand-offs of around 5" to keep a good centre of gravity with one bungee on each side of the camera.
on a fisher i always put a rotating off-set then a foot and a half of risers then a twin tube paddle mount and hang the bungee on the end, it works really well to keep the rotating off-set unlocked in shot for small moves left, right or in, out.
#3 ian mussell
ian mussell
  • 15 posts
  • Grip
Posted 13 December 2009 - 11:47 PM
oh and of course remember to safety everything, i heard of a bungee snapping recently!
#4 Jon Rosenbloom
Jon Rosenbloom
  • 713 posts
Posted 14 December 2009 - 04:54 PM
We did this quite a bit on "Big Movie w/ Big Actors." Fisher 11 is not optimal; Fisher 10 is better. Arricam LT is not optimal; I've been humping that camera for three months, and it's freakin' heavy!
Read the rest with the understanding that I'm describing the other Dolly Grip's rig, so I'm a little fuzzy on the details.
Don't use bungees; use surgical tubing and as many risers as you can. The main thing is for the rig to be as high as possible so that you maximize the benefit of the tubes' elasticity (so the rig takes the weight instead of the operator.) We just make one big loop of maybe a dozen strands of five foot tubing.
(Again, I don't know the exact specs on the surgical tubing. It will be best if you experiment with tubes of various length, width and wall thickness. I do know that that camera weighs about 60 pounds with a prime and a 1000' mag.)
You also need a ubange, two carabeeners, a daisy-chain runner, a short runner, and a ratchet strap. The short runner chokes the camera's handle. One beener connects the short runner to one end of the loop of surgical tube. The tube runs up through the outer ubange hole, across the ubange, down through the other hole, and gets clipped with the other beener to one of the loops of the daisy-chain, which is attached to the leveling head. The ratchet strap braces the tower of risers once you've got the weight and the height.
Sorry I can't be more specific. Make sure to work out the kinks with a couple of sandbags before you rig the production camera.
#5 Jon Rosenbloom
Jon Rosenbloom
  • 713 posts
Posted 14 December 2009 - 04:56 PM
Or you could just do what Ian does.
#6 Jeremy M Lundborg
Jeremy M Lundborg
  • 61 posts
Posted 14 December 2009 - 10:42 PM
I've seen the rigs around quite a bit recently and from my lack of experience I'd like to ask their importance.
What are they used for? Pros, cons?
#7 Chris Keth
Posted 15 December 2009 - 04:56 AM
I rigged something like this recently to shoot out the side door of a moving van. The camera was hung on tripled or quadrupled bungees threaded through the loop part of the door latch. Then a couple more bungees were threaded through the baseplate and attached to either side of the bottom of the door so that the camera was suspended in the middle of 3 lengths of bungees. It made a surprisingly smooth car rig.
I don't know what shots you need to accomplish, so I don't know if this info will be pertinent. You might find that a heavy weight and a bungee going below the camera is helpful as well. The camera will be in a sort of tension stasis that smoothes your input into the system.
#8 Jon Rosenbloom
Jon Rosenbloom
  • 713 posts
Posted 15 December 2009 - 08:38 PM
Most of the time, a bungee rig is used for "hand held" shots when the camera is too heavy to be hand held; such as when an Arricam has the 12:1 zoom and a 1000' mag.
#9 Chris Keth
Posted 15 December 2009 - 11:18 PM
I see, it's not so much a stabilizer as a plain old weight relief system!
#10 Saul Rodgar
Saul Rodgar
  • 1682 posts
Posted 16 December 2009 - 02:18 AM
I operated on a show last year where we were filming inside of a moving bus. At my suggestion, we hung the cameras with bungee cords from the overhead rails and the seats below and operated sitting on the bus seats. The director was sort of pleased with the resulting shots then --they were nixed later in post-- and we moved on to straight hand held camera work, which ended up being used in the edit.
#11 Saul Rodgar
Saul Rodgar
  • 1682 posts
Posted 16 December 2009 - 02:16 PM
Forgot to mention we were using HDX900s.
#12 Chris Keth
Posted 16 December 2009 - 05:19 PM
What made you want the bungees with such handholdable cameras? To me, they would be a hindrance unless absolutely needed.
#13 Tim Nuttall
Tim Nuttall
  • 23 posts
  • New York, NY
Posted 16 December 2009 - 09:20 PM
Chris,
Do you have any pics of this rig? Reaching tension stasis is key for what we want to do.
#14 Chris Keth
Posted 16 December 2009 - 10:03 PM
Chris,
I'm afraid I don't. The camera was an arri 416 and we were shooting out the side door of a 15 pass van with the side doors strapped open. One bungee was looped twice through the top handle and the door hardware so the bungee was doubled up the whole way. The others were just looped between the rods and the dovetail plate and hooked onto whatever they could be hooked to around the bottom of the van door. It was very simple. The weight was mostly hanging from the top bungee with the others controlling excess bounce.
#15 JD Hartman
JD Hartman
  • 1764 posts
  • Edison, N.J. U.S.A.
Posted 23 December 2009 - 02:13 PM
Something like this: http://www.cinemagad...unt-p-2276.html It's a MSE product: http://www.modernstu...om/aboutus.html
#16 michael best
michael best
  • 30 posts
  • Grip
  • La/SF
Posted 30 December 2009 - 02:19 PM
I did a show last year where we had to make a bungie cam at the last second for a F35 with a 20-290 lens. We just took and eye blot, into the 3/8 receiver on the top of the camera, and used 4 or 5 bungee cords we borrowed form effects, and tied them to the dolly offset. Set the lenght we needed on the bungees and the Camera op loved it. He said it worked better then the normal Modern bungee rig people used. The only thing you need to worry about is the knots you use with the bungee, as bungee expand and shrink a lot which can slowly cause the knot to come undone.
as for the fisher 11 well if you can go with a 10 or a hybrid it would be better, but you can counter weight the 11 and support the arm with a piece of 2x4 or speed rail. And for a riser used a 3' or a speed rail riser to get you to the height you want.
