how do i edit a (8mm)bmp-sequence?
7 replies to this topic
#1 Robert Jansen
Robert Jansen
  • 1 posts
Posted 17 December 2009 - 01:58 PM
I need some help with the editing of a 8 mm film. We shot the whole film with 8 mm camera's and digitalized the footage.
Now it's a bmp sequence, but i don't really now the best way to approach it in Final Cut Pro.
Someone tolled me you should edit with a converted smaller sized copy and once finished apply your project on the real master footage.
Does anyone have experience with this?
#2 John Young
John Young
  • 181 posts
  • Lexington, KY
Posted 20 December 2009 - 07:09 AM
Is your footage a bunch of little single frames? If so, I might try to convert that to an actual motion format, unless FCP deals well with the .bmp format.
Personally I have never worked with the bmp format. When you load your footage into FCP, what happens?
Are you able to edit it?
#3 Mark Dunn
Mark Dunn
  • 2670 posts
Posted 20 December 2009 - 08:09 AM
You need a splicer. These are the best
http://www.mondofoto...r-deluxe_3a.jpg
although this type is cheaper to buy but needs more expensive pre-cut tape.
http://www.7dayshop....s/prod_9141.jpg
and a viewer
http://retrothing.ty...zed/elmo912.jpg
and a couple of 200' spools.
They're not very expensive.
#4 Phil Rhodes
  • 12175 posts
Posted 20 December 2009 - 08:23 AM
If FCP won't load a BMP sequence, you could use something like ffmpeg to turn it into a Quicktime movie of some kind.
ffmpeg is a commandline tool and has a steepish learning curve, but there's a lot of help available online.
#5 Christopher Curry
Christopher Curry
  • 16 posts
  • Melbourne, Australia
Posted 20 December 2009 - 12:17 PM
There's a tiny (430kb) freeware program called JPEGVideo that can convert a series of pictures into an .avi file:
http://www.ndrw.co.u.../jpgvideo/index
All you have to do is organise the images (assuming they're in correct sequence) into a folder and the program makes a video file out of it. You would have to batch convert to the bitmap files to .jpg first. I'm not sure if an .avi file will directly drop directly into a FCP timeline without some prior conversion or tinkering.
Alternatively, there is JPEGAVi by the same developers which is a seemingly much more comprehensive program. You can use bmp files. Though, it's not freeware so you'll have to cough up a small fortune to use it:
http://www.ndrw.co.u...re/jpgavi/index
#6 Christopher Curry
Christopher Curry
  • 16 posts
Posted 20 December 2009 - 12:38 PM
Just realised that you can use JPEGAvi for a free 30 day trial but it will display a "Non-Registered Copy" title at the bottem of the frame during playback.
#7 Rafael Rivera
Rafael Rivera
  • 121 posts
  • San Jose, CA
Posted 20 December 2009 - 01:56 PM
Here're 2 methods:
Using QuickTime Pro
1. Do File>Open Image Sequence
2. Choose the 1st bmp image (these must be numbered)
3. Select the frame rate (you know how you shot it: 18, 24, 30 fps, etc)
4. Hit File>Save and you'll have an Uncompressed video, or choose File>Export and select your codec.
Using FCP
1. Start with User Preferences>Editing
2. Set Still>Freeze Duration to 00:00:00:01 (one frame)
3. Import all the images into your project, preferably into a new bin to keep things organized
4. Select all the images and drag them to a new sequence
VoilĂ , you now have a sequence you can nest into other sequences or you can simply export this sequence using the codec of your choice and reimport the resulting QT file.
#8 Saul Rodgar
Saul Rodgar
  • 1682 posts
Posted 20 December 2009 - 02:29 PM
Here're 2 methods:
Using QuickTime Pro
Using FCP
Yes, this is the best way to go at it.
