My $100 s16 high speed camera
9 replies to this topic
#1 Kristian Schumacher
Kristian Schumacher
  • 175 posts
  • Oslo, Norway
Posted 29 December 2009 - 10:02 AM
Hi all,
Just thought I´d share one of my camera projects with you. I had a really hard time getting info about this camera when I first got it, but got it running and have now done my kitchen-table-hack-job-s16mm-conversion. It looks a bit rough - gaffer tape to seal light leaks and so on, but seems to work perfectly up to 300 fps. Just as the people at Alan Gordon, I found that the camera would chew up the film at higher speeds than that. This is of course because I have removed one pull down claw and half the sprockets.
OK, so with power supply, tools and so on it cost more than 100$ - and quite a few hours - but I enjoyed it and hopefully some camera DIY-guys on this board will as well.
Shot a short demo of the camera here:
Kristian
#2 konstantin smola
konstantin smola
  • 25 posts
Posted 29 December 2009 - 10:16 AM
Nice!!!
But it only works with daylight spools, right?
Would be stoked to see footage shot with it!!
#3 Kristian Schumacher
Kristian Schumacher
  • 175 posts
  • Oslo, Norway
Posted 29 December 2009 - 10:43 AM
Nice!!!
No, it can take up to 400 ft on a core. The takeup I think needs to be on a 400 ft daylight spool. I made a little core adapter myself, and it worked fine to feed off. I haven´t tried take-up to a core, and don´t see the need. I have since got hold of a core adapter that is a bit more sturdy than the one I made myself. I used a 400 ft spool the first (and only) time I used the camera - that was before my s16 conversion. Just had to remember to get that spool back from the lab to use again.
The first footage didn´t come out that nice, but that wasn´t the camera´s fault ;-) That was also before I got the power supply working properly, so it only ran a bit under 200fps. I can still upload some short clips from the r16 footage to give you an idea. The image was at least rock-steady - and in spite of using regular perf film, not .300... I will give you the link when I have uploaded a clip to Vimeo.
I am making an underwater housing for it now - mainly for nature stuff, but I may try some surfing stuff as well. Fun-fun-fun!
Glad you enjoyed it,
Kristian
#4 Steve Acheson
Steve Acheson
  • 12 posts
  • Steadicam Operator
Posted 29 December 2009 - 11:12 AM
That seems pretty hard to tread Can you do it in the bag or the dark room?
#5 Kristian Schumacher
Kristian Schumacher
  • 175 posts
  • Oslo, Norway
Posted 29 December 2009 - 11:25 AM
It is a bit fiddly, yes ;-) I pull out about half a meter of film, tread the mechanism in the light. Then I do the cores/spools in the change bag. A little tricky, but not at all impossible. But the order is a little different to my video demo, as both feed and take-up spools go in last and in the dark.
K.
#6 Kristian Schumacher
Kristian Schumacher
  • 175 posts
  • Oslo, Norway
Posted 29 December 2009 - 04:02 PM
Here are a couple of clips on Vimeo at I think just under 200 fps.
Kristian
#7 Henri Titchen
Henri Titchen
  • 125 posts
Posted 29 December 2009 - 04:47 PM
Kristian,
Camera and results look great. The water splash footage is nice.
Which sprockets did you have to remove?
Did you find it easy to get pin-out/wiring information for this camera?
Thanks from,
H.
#8 Kristian Schumacher
Kristian Schumacher
  • 175 posts
  • Oslo, Norway
Posted 29 December 2009 - 05:10 PM
Kristian,
Thanks from,
H.
Thanks Henri,
s16mm uses only perforations on one side, the right if you stand behind the camera. So the top claw and sprockets - as you look into the camera when loading - were removed.
Finding info about the camera was difficult until I got hold of the manuals for mine and a few other models. I have uploaded it to my server for anyone interested:
http://kameraunderva...likenManual.pdf
Wiring is as it says in the manual, pins 10 and 11. I replaced the plug on mine, using an XLR connector.
Kristian
#9 Roger Todd
Roger Todd
  • 14 posts
Posted 03 January 2010 - 09:37 AM
Thank you so much for scanning and uploading that manual, and thank you too for the video showing how to load it with film - invaluable!
#10 Kristian Schumacher
Kristian Schumacher
  • 175 posts
  • Oslo, Norway
Posted 04 January 2010 - 10:26 AM
No worries, and I am glad you liked it. I have had so much good help from this forum getting my head around film cameras, so it is very nice if I can be of help to some too :-)
Kristian
