Soft FX Filter
#1 Chad Stockfleth
Chad Stockfleth
  • 622 posts
  • Louisville, KY
Posted 21 January 2010 - 11:06 AM
Can you get any blooming/halation from a soft fx filter in highlight areas?
I like the diffusion quality but would like a little blooming from a harder edge light.
If not, what else might I use?
Thanks!
Chad
Posted 21 January 2010 - 11:55 AM
Yes, it causes halation, it's just not quite as foggy as a ProMist. It's more like halfway between the look of a Black ProMist and a Classic Soft.
#3 Chad Stockfleth
Chad Stockfleth
  • 622 posts
  • Louisville, KY
Posted 21 January 2010 - 01:57 PM
Thanks, David. That sounds about right where I need to be.
#4 Tommaso Alvisi
Tommaso Alvisi
  • 6 posts
  • Bologna
Posted 21 October 2012 - 04:19 PM
Great info David!
So is the Soft/FX similar to the Classic Black Soft?
Which one do you suggest for a subtle diffused look with a slight halation of highlights?
Soft/FX 1/2 and 1 or Classic Black Soft 1/8 and 1/4?
(one for wides and one for mediums and cu)
Many thanks David.
#5 David Mullen ASC
Posted 21 October 2012 - 10:00 PM
Either would work, which you use just depends on which you like more as an effect. Classic Soft Blacks will give you a slight blurred bubble, or ring, or double-edge fringe around hot edges and points of light because the dimples in the glass are larger than that in Soft-FX.
#6 Bill DiPietra
Bill DiPietra
  • 2339 posts
  • New York City
Posted 22 October 2012 - 03:31 PM
Tiffen's SFX 1 gives the frame a nice amount of softness without it being too overt.
#7 Stuart Brereton
Stuart Brereton
  • 3347 posts
Posted 22 October 2012 - 05:05 PM
Soft FX are the only Diffusion I ever use. SFX 1 is great for softening close-ups on female talent without halation or loss of contrast.
