Upgraded 17EP-16APK motor of Konvas, steadicam edition
#1 Olex Kalynychenko
Olex Kalynychenko
  • 868 posts
  • Dnepropetrovsk, Ukraine
Posted 02 February 2010 - 10:34 AM
I wish inform you about new edition of upgrade of 17EP-16 APK motor of Konvas camera,
for use with steadicam.
This is 17EP-16 APK motor with new, modern electronics, base on 1414 controller, with 10 crystal sync speeds, digital film counter and additional power sockets of Battery distributor.
1. The motor have 10 crystall sync speed 6,25, 12, 20, 24, 25, 32, 33.33, 40, 48, 50 fps.
2. The fluent (soft ) motor acceleration and soft stopping. The motor have gradual acceleration of speed, and smooth deceleration, without jerk. The soft start very important for high speeds, because, the mechanism of camera to run without overload.
3. Shutter Parking stops the camera each time in the viewing position.
4. Manual adjust of phase ( Phase/Inch ) of speed at run mode and manual turn of axis on low speed at stop mode.
5 Wide system of sound information. The electronic confirm you correct loading of program with on of motor, at run of motor, at stop of motor, at stop of motor on fixed position, beep of not crystal sync speed.
6. Light signal of not crystal sync speed.
7. 4 pin XLR cannon power connector, international standard of power connector of cine and video equipments.
8 .International style of fuse holder for international glass fuses.
9. The electronics have protection from connect battery with reversal polarity
10. The electronics have high power output stage with high power reserve.
11. The additional film counter with 3 Digital LED display ( FC module )
The motor have additional 4 power sockets for connect of additional electronic modules.
This is version of motor can be use at steadicam with radio remote control.
The additional 4 Power sockets have contact of external input of Start-stop signal of motor.
This is Arri standard signal ( + 12V-- RUN, 0v --Stop ).
But, The electronic of motor can read of external; start signal with value from 2.7v up to 16 v.
Motor have RED led of external Run signal and on-off switch of external RUN signal.
At any time, you can check of radio track of external Start-stop signal without run of motor, if you set switch on " off" position, but, the RED led will show you external signal " RUN".
This is sockets can be use for external wired remote control unit too.
All technical details by PM.
#2 Saul Rodgar
Saul Rodgar
  • 1682 posts
Posted 03 February 2010 - 12:12 AM
Can it be used with a 1M? And what is the price? Thanks.
#3 Olex Kalynychenko
Olex Kalynychenko
  • 868 posts
Posted 03 February 2010 - 05:55 AM
Yes, of course, upgraded 17EP motor can be use with Konvas-1M camera ( 1KSR-1M ).
The crystal sync speed controllers can be use for upgrade of other type of cine cameras too.
Please, visit
http://sites.google....-motors-upgrade
You can find technical information about controllers, to choose of best version of upgrade of your motor, to find of finished upgrades for example and can tell me your additional requests.
This can be full functional wired remote control, start-stop remote control, remote control with radio channel and more ets.
I prefer to discuss of your technical requests and price by PM olex.camera@gmail.com
The final price depend from type of controller, quantity of speeds, additional service electronic modules.
