TV sync, Arri ECU-1?
#1 Alex Worster
Alex Worster
  • 113 posts
  • Film Loader
Posted 03 February 2010 - 04:30 PM
Need to sync an SR3 Advanced to a regular old CRT TV. Arri makes an ESU-1, will that work? If so how do I use it? I found a manual online but it doesn't explain its operation well. Any other ideas aside from the ECU-1? Thanks!
Edited by Alex Worster, 03 February 2010 - 04:34 PM.
#2 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 14 March 2010 - 06:49 PM
Should be able to do it with a simple shutter adjustment, 144º is the magic number :)
#3 John Sprung
John Sprung
  • 4635 posts
Posted 15 March 2010 - 12:01 AM
The 144º trick is fine if the TV isn't particularly prominent in the shot. It doesn't eliminate the roll bar, it just reduces the size of the roll bar to -- in theory -- zero lines. There's still a horizontal offset. If you're doing a CU of the TV set, that probably won't be good enough.
