Strobe Lighting
#1 Matteo Cocco
Matteo Cocco
  • 45 posts
  • Germany
Posted 06 February 2010 - 10:50 AM
Hello everybody,
Does anyone have any link to videos showing the result of Strobe Lighting with the Red One camera shot in 4k.
And if you don´t have any samples, please tell me your experience with Strobe effects and HD cameras...
Thanks a lot,
Matteo
#2 Adrian Sierkowski
  • 7375 posts
Posted 06 February 2010 - 10:54 AM
It sucks, as you generally wind up getting 1/2 the frame exposed. Just look for "rolling shutter effects" it'll be approximately the same for any CMOS camera system unless you can sync the camera and the strobe to make sure it's even over the whole exposure.
found this:
#3 Matt Read
Matt Read
  • 122 posts
Posted 07 February 2010 - 02:29 AM
Yuck. That does suck. Thanks for posting this. I hadn't realized this was an issue with CMOS sensors. Just another reason why film is better.
#4 Tama Berkeljon
Tama Berkeljon
Posted 07 February 2010 - 03:30 AM
found this:
Hey everyone..
Exactly Adrian. It is usually a real problem.
Like also in this music video (look at the flash effects from about 2:13)
These flash effects were produced using our Creamsource LED Lights, simply pulsed (they have a flash button as well as being a flicker-free light source, confusing, I know..) But unfortunately at the time of this music video we had not yet released our sync system (we called it Creamsync) that allows you to take an external sync signal and lock both the RED camera and the light together, so that a frame would not be "broken" I.E. a flash starting or stopping part way throgh the frame and causing what we call flash-banding.
As far as we are aware, this is the first system available to overcome this issue, I would welcome any news to the contrary though ! :)
We're due to put some videos up of the comparison between a synchronised flash and a non- sync flash on the Red fairly soon.
If you're interested, check back to my blog over the coming week, where I will post the video . (the brief explaination / example has been shot, it just needs to be outputed to the right format, which should happen in the coming days .) http://tama.typepad.com/blog/
If you are unfamiliar with our lighting equipment, have a little look at our site (www.outsight.com.au) and please feel free to contact us for more info regarding the lights, especially if you are interested in the flash/ sync issue as I'm aware that we dont yet have a lot of info up on the site about it.
As far as I have seen, the flash-banding effects with some CCD type cameras are not quite as bad as that experienced with the Cmos based cameras, due to the rolling shutter in the Cmos . So if you have a choice, and a chance to test, perhaps CCD may yield better results with a non-sync flash source such as a camera flash or party strobe.
Other than that, if you absolutely need to use a strobe for a sequence using a Cmos based camera, if you can, keep your strobe lengths quite nice and long, it may help, (just somethng we picked up while playing around) and obviously if you can minimize the frequency of the strobes, and total effect of the strobe on the overall picture, then this does help also (put it further away, or turn it down more).
Best of luck, I look forward to hearing how you go !
Tama.
#5 timHealy
timHealy
  • 1262 posts
Posted 07 February 2010 - 04:56 PM
found this:
you can get partial frame flashes with a film camera if the strobe is not synced up with the shutter or the strobe flash is not longer than the exposure. For an example of the top of my head is when ripley gets on the escape pod at the end of alien. you can clearly see the strobes coming in and out of sync with the shutter. It might work for some things and not others.
best
Tim
#6 Tama Berkeljon
Tama Berkeljon
Posted 17 February 2010 - 07:46 AM
Hey all,
If anyone is interested,
Here is a link to my blog and also to the Vimeo video showing the really basic Sync test we did with the Red camera showing the diference between sync'd flashing light with a rolloing shutter and non- sync'd light, using our Brand new Creamsync system.. Hope it generates some ideas and maybe will go towards alieviating some problems !
all the best ,
Tama.
Permalink to that post on my blog :
http://tama.typepad....sh-banding.html
or the Vimeo link :
Edited by Tama Berkeljon, 17 February 2010 - 07:48 AM.
#7 James Brown
James Brown
  • 235 posts
  • Sydney, Australia
Posted 18 February 2010 - 09:38 AM
or the Vimeo link :
Thanks for that - much appreciated.
Cheers, James
