Quick Question about ASA
#1 James Onn
James Onn
  • 1 posts
Posted 08 February 2010 - 11:00 AM
Basicly I have just got my new Super-8 Camera through the post and it says that the 4 types of film it takes are :
25D 100D 40T 160T
Now I was thinking about buying Some Kodak Tri-X 200D Super-8 Film but I was wondering what steps I would need to take or if it is even possible (or at least advisable) to use this film With this camera.
Am I correct in thinking that it bay become over exposed? - I was however planing to shoot in low light, / shade.
Finally I would just like to request any general tips for selecting super-8 film, and how to generally work with using the same film for multiple conditions (outside daylight, inside, night, etc...)
Thanks in advance.
- James
Posted 08 February 2010 - 11:56 AM
Does your camera allow manual exposure?
#3 Chris Burke
Chris Burke
  • 1720 posts
  • Boston, MA
Posted 08 February 2010 - 02:18 PM
25D 100D 40T 160T
Thanks in advance.
- James
what is the make and model of your camera?
#4 Jim Carlile
Jim Carlile
  • 464 posts
Posted 09 February 2010 - 04:37 AM
If your camera can read 160T, just cut a filter notch in the cartridge so that the camera's filter pin will stay out
Without the notch, Tri-X will push in the filter pin, causing the camera to set the meter at ASA 100, which is one stop overexposed. With the filter pin out the meter will rate it at ASA 160 -- much better.
The same is true of VISION 200.
On some cameras the notch will make no difference, because they don't do the automatic 2/3 stop kickdown-- newer ones, especially. But just to be sure, cut a notch.
With Tri-X you don't need an 85 filter, so keep the filter switch set to bulb. It'll give you more sensitivity in low light situations.
