What kind of connector is this?
#1 John Waterman
John Waterman
  • 49 posts
  • Chicago
Posted 21 February 2010 - 02:20 PM
Hello fellow ACs,
I just took delivery of a Cinetape Measure System, and noticed that the display has a wedge shaped cavity on the back to connect to a bracket or arm or something. I asked Cinematography Electronics about it, and they said that they were going to make a bracket for the display, but never did. I know I've seen this type of connector before somewhere, Panavision maybe?
Any ideas what can connect to this? I've attached a picture of the back of the cinetape.
Edited by John Waterman, 21 February 2010 - 02:21 PM.
#2 John Sprung
John Sprung
  • 4635 posts
Posted 21 February 2010 - 02:54 PM
The machine shop term for that kind of attachment point is a "Gib lock". There aren't standard sizes or shapes, except that mostly they're done with a 45 degree angle milling cutter. They're so easy to make that most machinists just roll their own. Any shop that has a vertical mill can make some mating parts for you.
#3 John Waterman
John Waterman
  • 49 posts
  • Chicago
Posted 21 February 2010 - 09:31 PM
It also has a small notch where a spring lock can click in place. I have some vague recollection of a noga arm where you press a button and lock it into an on-board monitor with this type of mating connection. Anyone know of on-board monitors or noga arms with this type of a connection?
#4 JD Hartman
JD Hartman
  • 1764 posts
  • Edison, N.J. U.S.A.
Posted 04 March 2010 - 04:48 PM
I think he means dovetail, usually the angle is 45 or 60 degrees.
