Kodak 35mm still photography film stock comparable to (Kodak's) 16mm film stock
#1 Mike Maliwanag
Mike Maliwanag
  • 20 posts
Posted 22 February 2010 - 05:44 PM
So I would like to shoot some tests with Kodak 35mm still photography stock that is comparable to 16mm film stock 500T 7219. A professor of my suggested taking 5219 film stock and loading into a photography canister to expose as stills in a SLR camera. He also mentioned that some companies provide this service. My two questions are where can I find such companies and is there any 35mm still photography film stock that resembles 16mm 7219 stock.
Mike
#2 Adrian Sierkowski
  • 7374 posts
Posted 22 February 2010 - 05:48 PM
Why not just ask Kodak for a 100' or 400' test load of the '19? In reality that's the best way to do it and you can knock out a camera/lens test at the same time. In my experience they've been very good in providing me with rolls to test out.
#3 Charles MacDonald
Charles MacDonald
  • 1157 posts
  • Stittsville Ontario Canada
Posted 22 February 2010 - 09:46 PM
HI Mike, to answer your second question first, 5219 is the same basic stock as 7219, but made on a 35mm or larger base. the difference in numbering is the way that Kodak's long standing number system works. You can probably find a 100ft of 5219 relatively cheep as a "short end". You will then have to load it in the dark into a reusable 35mm cassette like you can get from dealers like Freestyle Sales. (http://freestylephoto.biz/ )
Your first question is a bit harder. Look in this site for the threads on "RGB Colour Lab" Short answer is that many of us are looking for a lab that will still do this on a regular basis. The lab you will be sending your main work may be able to suggest someone that will do a couple of rolls for you. for a Movie lab to run 6 feet of film, and make a print is hard to do. Only by Printing the neg on Motion Picture stock, or by scanning it on a scanner simalar to what you are using if you do Digital intermediate will your tests be realistic.
