Motion control Russian arm?
#1 Tony Brown
Tony Brown
  • 689 posts
Posted 26 February 2010 - 05:37 AM
Anyone know of a rig, preferably Euro based, that can 360 a moving car but be motion controlled?
#2 ian mussell
ian mussell
  • 15 posts
  • Grip
Posted 26 February 2010 - 12:00 PM
hi tony,
is the car driving during the move?
just a level 360 or jibbing up and down through out the move?
ian mussell
#3 Tony Brown
Tony Brown
  • 689 posts
Posted 26 February 2010 - 12:07 PM
hi tony,
ian mussell
It will be moving. Ideally we'll jib of course, the odd bump and jolt |I think we can accommodate by shooting slightly wider that required and stabilising. If it were not for the jib I think it would be relatively simple to motorise the lateral arm movement.
#4 Onno Perdijk
Onno Perdijk
  • 87 posts
  • Grip
  • www.solidgripsystems.eu
Posted 26 February 2010 - 04:43 PM
Hello Tony,
Does it really needs to be MotionControl? Or could you do with a repeatable movement as well?
Maybe this could do the job aswell: Move 'n shoot
Good Luck,
Onno
#5 Tony Brown
Tony Brown
  • 689 posts
Posted 26 February 2010 - 04:52 PM
Hello Tony,
Good Luck,
Onno
Thanks I've worked with that rig and cannot recommend those guys highly enough, but we need a 360 MoCo ideally
#6 ian mussell
ian mussell
  • 15 posts
  • Grip
Posted 27 February 2010 - 12:15 PM
as far as i know there is nothing already in existence for moco, only repeatable.
all i can suggest is to get in touch with the guys at alpha grip they may well be able to sort something for you.
#7 Olex Kalynychenko
Olex Kalynychenko
  • 868 posts
  • Dnepropetrovsk, Ukraine
Posted 27 February 2010 - 12:42 PM
The RUSSIAN ARM and the Flight Head is remotely - operated gyro-stabilized camera crane system that keeps the camera steady while going at high speed, across bumpy roads or off-road. Lightweight design allows the crane to be mounted on the roof of almost any camera car, boat, train or other mobile platform
http://filmotechnic....uipment/46.html
#8 Tony Brown
Tony Brown
  • 689 posts
Posted 27 February 2010 - 01:10 PM
Thanks Olex, I've used it the Russian arm.
#9 Onno Perdijk
Onno Perdijk
  • 87 posts
  • Grip
Posted 27 February 2010 - 05:00 PM
Hello Tony,
I think a flighthead and a russian-arm as a combination does not gonna help you.
I would suggest to use a russian-arm-light-version for the rotation only and get an other remotehead like the ultihead from MrMoCo for the MoCo part of it.
At the other hand: You will need a MoCo rotation, a Moco Jib, and a Moco Tilt (to compensate for the jib-movement). This seems more a Moco job to start from and then enter the grippery ;-). I would suggest to contact Mark Roberts for a customized rig.
I am not done in getting my head around a decent solution... <_<
I'll be back!!!! :rolleyes:
Good Luck,
Onno
