FUJI F-64D
#1 Rob Webster
Rob Webster
  • 53 posts
Posted 28 February 2010 - 06:53 PM
Hello.
How does Fuji's F-64D fare, in terms of grain, saturation and dynamic range, when compared with newer emulsions?
I will be shooting day exteriors on a S16 short, and my main concern is to avoid excessive grain and colour saturation. I would be grateful for any observations you can share.
Thank you,
Rob
  • 20072 posts
Posted 28 February 2010 - 07:25 PM
Hello.
Thank you,
Rob
It's fairly fine-grained being only 64 ASA -- it's a bit more contrasty and saturated than the Eterna stocks, closer to the Vivid 160T look. It's not as sharp and fine-grained as the Kodak Vision-2 50D stock is, however. Being Super-16, there are limits to how grainless the image is ever going to look. But 64D is a nice emulsion, I find it a bit softer and cooler than the Kodak 50D stock.
#3 Chris Burke
Chris Burke
  • 1720 posts
  • Boston, MA
Posted 28 February 2010 - 08:33 PM
Hello.
Thank you,
Rob
Like most Fuji stock, it really likes to be over exposed. I would rate it at 40 or even 32. This will give you more saturation, but it isn't excessive. I highly recommend it.
#4 Saul Rodgar
Saul Rodgar
  • 1682 posts
Posted 28 February 2010 - 09:19 PM
In my experience, 8622 is grainier and has less dynamic range than comparable Kodak stocks (7201, 7212, etc). Not a fan, unless I am going for that grittier, cooler look. For daylight filming, particularly landscape, I much prefer 7201 or corrected 7212.
#5 Rob Webster
Rob Webster
  • 53 posts
Posted 01 March 2010 - 07:18 PM
How does it compare with Eterna 250D, specifically?
Dynamic range and grain, as mentioned above, are a priority.
Thanks again for your valuable input.
Rob
#6 Chris Burke
Chris Burke
  • 1720 posts
  • Boston, MA
Posted 01 March 2010 - 10:34 PM
Rob
the eterna 250D being a newer more modern stock has a more dynamic range. Grain would be similar
#7 K Borowski
K Borowski
  • 3905 posts
Posted 02 March 2010 - 12:41 AM
250D being newer is secondary. It's two stops faster, so it will still be much grainier. Because it is faster though, unless you overexpose 64D maybe a full F/stop, the dynamic range of 250D should be wider because the faster stock can see into the shadows better.
The way I understand it, the faster stocks blend faster, bigger grains in while still having slower, smaller grains as well.
I always shoot the slowest stock I can get away with, but it is important to not bring something so slow you'll get burned by not having enough light to shoot. . .
