Storm Blue filters
#1 Duran Levinson
Duran Levinson
  • 6 posts
  • Cape-Town, South Africa
Posted 02 March 2010 - 06:01 AM
Hey!
I am shooting an experimental student film next month and I want to achieve a blue semi-desaturated look for my interior. Can anyone recommend any filters, I checked out Storm blue filters and thought it would be good in conjunction with 7219 but I am worried about one factor. My film has no red in it, and I want to stray away from orange lighting, i want soft, cold lighting.
Any recommendations will be great
  • 20069 posts
Posted 02 March 2010 - 10:16 AM
Hey!
If you are shooting daytime interiors, a tungsten stock like '19 without any correction filter should be blue enough for you.
In tungsten lighting with no mixed daylight sources, all blue filters & gels suck a lot of exposure... but you can either add 1/2 blue gel to the lights or a 1/2 blue filter for a cold effect, then if necessary, time more blue in post.
#3 Eric H
Eric H
  • 29 posts
Posted 02 March 2010 - 11:10 AM
I have used some filters thru www.camerafilters.co.uk made my Harrison called Blue/Grey...they come in a graduated set of 5 or 6 (don't really remember).
I shoot tungsten balanced stock without correct and used a little CTB on my HMI's.
the result is on my site....under recent work...it's all the Manpower spots towards the bottom of the page.
I used at least one of the filters in camera and tweaked in post. As you can see, they all have a desaturated look, but there still is a lot of room to play in telecine.
I posted a still here from one of the spots....I vaguely remember using one of the lightest filters on this and added 1/8 CTB to my HMI backlight It was cloudy out and the color temperature was up near 6500-7000 Kelvin. if you can get your hands on some filters...it's easy to test nowadays with your trusty DSLR.
Eric Halberstadt
www.spitfirefilms.com
Hey!
#4 Duran Levinson
Duran Levinson
  • 6 posts
Posted 02 March 2010 - 02:40 PM
Thanks so much!
The website says it is under construction though :(
Another filter question:
I also have a montage scene in which I want a very olden feel, i know tobacco filters and antique suede filters work well for this but i also want to have soft blown out highlights. I am interested in blowing out highlights.
Can you recommend any filters to check out.
I also have the option of shooting the montage on a Bolex so i can play around with the shutter angle, but then how would i create that olden style feel without 4x4 filters?
Cheers
#5 David Mullen ASC
  • 20069 posts
Posted 02 March 2010 - 03:26 PM
ProMist filters are probably the easiest thing to find for that sort of diffusion effect.
#6 Eric H
Eric H
  • 29 posts
Posted 03 March 2010 - 02:10 AM
my website is under construction?
can't be.
or
www.erichalberstadt.com
Thanks so much!
