DVX100 ANDROMEDA
12 replies to this topic
#1 ryan knight
ryan knight
  • 115 posts
Posted 07 March 2010 - 06:29 PM
Does anybody think, at this point in acquisition technology, its worth buying a (well-priced) used DVX100 Andromeda?
RK.
#2 Aaron Solomon
Aaron Solomon
  • 84 posts
Posted 30 March 2010 - 12:12 PM
Depends on what your shooting, but I would go with something at 1280 x 720 at least at this point, like the HVX-200, which can also reach 1080.
#3 Adrian Sierkowski
  • 7374 posts
Posted 30 March 2010 - 04:59 PM
Be careful on the HVX, it's not "really" 1080. It does some interesting things with pixel shifting, but it doesn't have a "full" hd sensor block. If memory serves, it's somewhere around 960x520, or some strange number there'bouts.
#4 Saul Rodgar
Saul Rodgar
  • 1682 posts
Posted 30 March 2010 - 06:52 PM
The DVX Andromeda is an aftermarket mod to DVX100s where they tap into the sensor, bypassing the limitations of the DV compression and colorspace:
"The Andromeda system allows recording of 4:4:4 (Full RGB) Uncompressed digital video from your Panasonic DVX-100P/AP/B. Bypassing the in-camera processing, the Andromeda system utilizes the full 12-bit color precision available inside the camera, and yields additional dynamic range, particularly on the highlights. The dynamic range gains have been measured to yield a total of approximately 9.5 stops latitude, which is about a 2.5 stop improvement over the standard DV output. "
http://www.dvinfo.ne...-available.html
They seem to have gone out of business since I last heard about them. They had plans to modify the HVX200 as well. Dunno what came of that. The DVX Andromeda shot HD in some configuration, can't quite remember now. Here is some more info:
http://www.dvinfo.ne...our-hvx200.html
If the price was fantastic, I'd consider buying one, taking into account that the folks who modified it seem to have vanished and that support is probably out of the question at this point in time. ;)
#5 Aaron Solomon
Aaron Solomon
  • 84 posts
Posted 30 March 2010 - 09:18 PM
Thanks Adrian. Just wondering I was shooting some stuff on the HVX a week or two ago and I noticed a ton of chromatic abberation that was probably from the new wide angle lens this guy had just bought but I was wondering if you'd had any trouble with that and if it was a prism alignment problem? Can the prisms slip out of alightment and create chromatic abberation like that?
#6 Gary Lemson
Gary Lemson
  • 155 posts
  • Santa Cruz Mountains
Posted 14 April 2010 - 08:03 AM
...it's somewhere around 960x520, or some strange number there'bouts.
960x720
#7 Gary Lemson
Gary Lemson
  • 155 posts
960x720
#8 Gary Lemson
Gary Lemson
  • 155 posts
Posted 14 April 2010 - 08:04 AM
960x720
#9 Gary Lemson
Gary Lemson
  • 155 posts
Posted 14 April 2010 - 08:09 AM
960x720
Whoa! I apologize for the repeat posts…not sure what happened.
#10 Gary Lemson
Gary Lemson
  • 155 posts
Posted 14 April 2010 - 08:13 AM
Could you elaborate on "chromatic abberation"? I've been running with HVX since they can out, an have noticed "interesting" characteristics.
#11 Aaron Solomon
Aaron Solomon
  • 84 posts
Posted 14 April 2010 - 10:10 PM
Chromatic abberation is when different wavelengths of light are focused at different points because of the different wavelengths at which light travels, resulting in the final image looking as though there are replica images of a slightly different color around it. Normally its caused by different wavelengths of light passing through the lens but I was wondering if having prisms out of alignment could also do it.
#12 Gary Lemson
Gary Lemson
  • 155 posts
Posted 15 April 2010 - 03:12 PM
Chromatic abberation is ...
Yes, understood. I’ve heard some folks refer to this as dispersion or distortion. With regards to your question, I will check with optics experts that I work with.
#13 Anthony Wike
Anthony Wike
  • 1 posts
  • Oklahoma City
Posted 12 November 2013 - 09:19 AM
Could be wrong to an extent, but I am sure that the problem is when you installed the wide angle extension, the additional glass elements on the extension caused the light to bend and slow down way more than what the cameras triple sensor prizm split is calibrated for. This is one of the things that a single sensor has on the triple sensor set up, the chroma sampling is WAY better than any bayer could ever be, BUT, the calibrations and measurements for the lense elements are MUCH more sensative. And yes, they can be thrown off, just a single drop to the ground from waste height can ruin a prizm set up, or any other camera's sensor alignment for that matter.
