Daylight or Tungsten?
#1 Stephen Price
Stephen Price
  • 84 posts
  • Digital Image Technician
Posted 09 March 2010 - 01:41 AM
Hello,
As both the 5D MKii and 7D are CMOS sensors, are they like most CMOS chips and prefer daylight balanced light? Is there a sensitivity difference between these two colour temperatures? And does using Tungsten light produce more noise in the blue channel like a RED?
If you were to shoot table top subjects in a studio, and had a choice of either 3200k or 5600k, what would produce the cleanest image?
Many thanks
Steve
#2 James Brown
James Brown
  • 235 posts
  • Sydney, Australia
Posted 09 March 2010 - 06:21 AM
I personally found that it did not have the same sensor response as a red. From my experience shooting at roughly 100-400 ISO i couldn't tell the difference even projected on a large screen.
Cheers, James.
#3 Noah Yuan-Vogel
Noah Yuan-Vogel
  • 23 posts
  • New York, NY
Posted 08 April 2010 - 01:36 PM
It definitely does make a difference. Here are some very basic tests I did regarding shadow noise levels for varying ISO/WB settings: http://www.dvinfo.ne...oise-tests.html (the second image first column should be labeled WB not ISO) These of course dont tell you anything about any of the other characteristics of the image, but I think it gives you a narrow view that helps give a pretty good idea of what to do if you absolutely want the cleanest shadows. On the other hand, I always use HTP despite the negative impact on shadow noise since I always prefer more highlight detail. I only ever turn it off if working with a scene that is low enough contrast there is no chance of anything coming within a stop of blowing out, or if the scene has a lot of important detail in the highlights since things get a bit washed out in the highlights with HTP as highlight contrast is reduced. Clearly 5000k is the best WB to use, as expected for a silicon-based imaging sensor.
I do agree that the difference is not as pronounced as in RED ONE, though.
Edited by Noah Yuan-Vogel, 08 April 2010 - 01:37 PM.
#4 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 08 April 2010 - 05:09 PM
Thanks for sharing those tests, Noah! I've downloaded them for reference, hope that's ok. :)
