monitoring 7d
7 replies to this topic
#1 Rob Featherstone
Rob Featherstone
  • 55 posts
Posted 18 March 2010 - 11:08 AM
I was wondering if any one has any tricks for monitoring the 7D.
Last time I used the Marshall V-LCD651ST-HDMI and toggled between hdmi
while I was lighting and standard def to feed the client monitor while operating.
Any one have any fantastic solutions?
-Rob
#2 Hal Smith
Hal Smith
  • 2280 posts
  • OKC area
Posted 18 March 2010 - 09:25 PM
-Rob
email these people http://www.converter...converters.html and see if they have any ideas. They've got all sorts of HDMI toys. What you need is an HDMI distribution amp with one port driving the Marshall and another a programmable HDMI to component scalar converter (AKA downconverter). You need programmable scaling because most HDMI to component converters simply pass the HDMI's HD format on to the component outputs.
#3 David Mullen ASC
Posted 18 March 2010 - 10:41 PM
I heard that when you are recording, the HDMI-out only sends out 480P -- is that correct?
#4 Ryan Thomas
Ryan Thomas
  • 85 posts
  • Grip
  • San Francisco
Posted 18 March 2010 - 11:01 PM
Rent the AJA black magic box. You've gotta get two monitors though.
Then you go HDMI into the black magic box, then go SDI to your onboard, and SDI to your production monitor....Or just have those two monitors be one in the same.
That's the only decent solution I've come across. The other thing you can do is get an HDMI splitter, but I just sorta hate those HDMI cables, especially with longer runs.
Edited by Ryan Thomas, 18 March 2010 - 11:02 PM.
#5 Rob Featherstone
Rob Featherstone
  • 55 posts
Posted 19 March 2010 - 05:24 AM
Yes. In fact on the Marshall monitor I used you only get a tiny image in the middle of the screen.
So Hal's idea to use the scalar seems like a good way to go.
TCS Film in NYC is going to provide me the black magic box for this next shoot.
Thanks everyone!
#6 Ram Shani
Ram Shani
  • 735 posts
  • isreal
Posted 20 March 2010 - 01:30 AM
hi
i use 3 combinations (depend on the situation)
1- use SD output with splitting between monitors
2- use blackmagic splitter (hdmi-SDI) but the Abel tech one with adaptor for battery
or you can use this one its hdmi-hdmi and recommend by philip bloom :http://philipbloom.co.uk/2010/03/17/absolutely-essential-bit-of-kit-for-the-dslr-filmmaker/
3- use the usb port to my laptop using the canon software to view and control the camera
the advantage is that the camera screen doesn't go black and you monitor and CONTROL the camera from the laptop
the problem is that it's not play at full play back like 24/25p but more like 20p (but it record normal)
Canon 7D has an output of 1620×910 via hdmi.
#7 Rob Featherstone
Rob Featherstone
  • 55 posts
Posted 21 March 2010 - 10:24 AM
thanks Ram:
That's great information.
Do you know if there is a way to record the usb feed. say at a different frame rate.
Like 6fps?
Thanks!
#8 Ram Shani
Ram Shani
  • 735 posts
  • isreal
Posted 24 March 2010 - 04:00 PM
you can only record video to the the card!
but you have 100% control over the camera
BTW
stills you can record to the computer
