rough test comparing HD frames of Red, EX3, and Canon DSLR
7 replies to this topic
#1 David Mullen ASC
  • 20069 posts
Posted 26 March 2010 - 11:31 AM
I just did some rough tests, nothing scientific, comparing the Red (downconverted from 4K HD to 1080P) to the EX3 and the Canon 550D T2i. The Red had a Zeiss Super Speed on it, the EX3 had the stock lens, and the Canon had to the stock 18-55mm zoom, which I acknowledge is not a good lens, but I did shoot it at f/5.6.
Here are some cropped portions of a chart I shot at 1600 ASA to test for noise in low-light. The EX3 was shot with a +6db gain boost to match the Red and Canon set to 1600 ASA. I didn't shoot the charts exactly the same size hence the mismath in the cropped size. But I didn't resize the 1920 x 1080 frames, I just cropped them down. They are compressed JPEGS though.
Cropped 1600 ASA Red frame
Cropped +6db EX3 frame
Cropped 1600 ASA Canon frame
  • 20069 posts
Posted 26 March 2010 - 11:56 AM
Here is a focus chart. Again this is not properly done in terms of distance from chart to lens, so don't try counting lines or anything, it's just to give me a rough impression of the sharpness difference for a 1080P project.
The Red was converted from 4K HD to 1080P with no sharpening. The EX3 was shot with Detail OFF. The Canon had the Sharpness set one notch above O.
I removed the color from the JPEG just because I found the differences in the color tone of the white backgrounds distracting, but there is a faint amount of color aliasing in the Canon test if you see it in color.
Cropped Red frame
Cropped EX3 frame
Cropped Canon frame
What all of this tells me is that the EX3 is more intercuttable with the Red for an HD show than the Canon 550D T2i is. The only difference is that the Canon would have the same DoF as the Red. But sharpness-wise, not to mention having all the controls of a pro HD camera, the EX3 is a better overall camera than the Canon in video mode. Size & weight & cost, of course, the Canon is the best. I did these tests to tell me what I can get away with when shooting an action scene in terms of slipping in some shots made with these other smaller cameras.
#3 Adrian Sierkowski
  • 7371 posts
Posted 26 March 2010 - 12:29 PM
Well I could've told you that David ;)
Nice job on the off the cuff tests, I'm not really surprised by the results. Speaking of, have you seen that Zacuto test of DSLRS -v- 35mm?
Just a side thought, perhaps another nice side test would be to see how much effort it'd take to get the colors to match on the cameras.. . Take a stock scene, and shoot each camera balanced for it with a typical skin tone, see how they reproduce and then buddy up with a colorist and see how much finagling you need to do? Just a thought.
#4 John Sprung
John Sprung
  • 4635 posts
Posted 26 March 2010 - 01:38 PM
Of course it's dangerous to read too much into what I can see on the computer here.
That being said, the Red and Sony do appear to be pretty much a wash for aliasing on the Marconi chart. It's the "C" blocks that get them both. The Canon aliases far more severely. It would be interesting to see those in color, because we should expect that the Bayer sensor of the Red might show us the two different Nyquist limits, green vs. red and blue.
Even more dangerous is to read much into the steps -- but the Red appears not to give us much room if any between the bottom two. The other cameras look like there's plenty to work with for the whole scale.
#5 David Mullen ASC
  • 20069 posts
Posted 26 March 2010 - 01:41 PM
Don't read anything into the steps, I adjusted the levels in Photoshop at either end to make black black and white white so probably tweaked a bit of the way the steps look.
#6 Saul Rodgar
Saul Rodgar
  • 1682 posts
Posted 26 March 2010 - 02:51 PM
Thanks for posting, David. As Adrian suggests, we suspected that the EX1-3 would win hands down on sharpness vs the Canon 550 DSLR. But it is nice to see side by side comparison.
Perhaps the Canon DSLRs wouldn't match the sharpness of RED, but it could maybe match 3 perf 35 mm (in terms of sharpness only). Some people who are routinely using the 5D and 7D in professional settings, most notably Shane Hulbut, ASC, hint as one of the main reasons they use them is not necessarily their sharpness --but the softer more film like quality to the image, digital artifacts, picture limitations and tight post options notwithstanding.
#7 John Mastrogiacomo
John Mastrogiacomo
  • 210 posts
  • Las Vegas, NV
Posted 01 April 2010 - 03:57 AM
The Cannon 550D's strength lies in it's low light and shallow DOF performance plus it's stealth operation and ability to get shots in very tight quarters. I put my 35 year old Pentax Takumar 50mm f1.4 lens on it with a $20 adapter and was very impressed. The lens is great and has about a 220 degree throw for focusing. If you can find one on e-bay get it!
I did a few tests with wide shots (Canon 15-85mm lens) in deep focus and the aliasing is unacceptable. Tile roofs and brick walls go bonkers - trees are OK. I can reduce it a little in post but not enough.
It's a great camera for stills and time-lapse. If I only use it for stills I'm happy, plus when an improved version comes out I still will be able to use all my Canon and Pentax lenses.
I love the fact that I can download the video directly from the camera with a USB cable - and it is very fast.
#8 John Michael Corey
John Michael Corey
  • 27 posts
Posted 06 April 2010 - 05:47 AM
David,
Seeing that you considered the Canon 550D T2i for sneaking in an action shot or two in a 1080P project, have you considered testing the Panasonic Lumix GH1 as well?
Thanks.
